Old style banjo differential modifications
Discussion in 'The Hokey Ass Message Board' started by Mad Bomber, Dec 25, 2011.
  1. Mad Bomber
    Mad Bomber
    from Missouri
    Greetings,
    Seeking info from the experienced crowd.
    1. Can you make the old style diff into posi track?
    2. Whats the highest gear ratio for the old style diff? Looking for a salt flats gear combination.
    3. Has anyone ever had their oldstyle axles cut for a second key? considering the keys shear quite easily. Want to keep everything as stock as possible, appearance is important.
    Thanks,
    Mad Bomber
    Bknuckle47@gmail.com
  2. Merry Christmas. I too am interested in the possibility of a posi for these old diff's.
  3. gas pumper
    gas pumper
    #3. keys shear because the hub and axle taper don't fit good. Clean burrs off, and lap the hub to the axle with valve grinding compound. The key does not take the force, it just located the hub. The taper locks the two parts together. I think 225 ft/lbs on the nut.
    One problem solved.:)
  4. juniorsrodshop
    juniorsrodshop
    from nh
    quick change... to get the gearing... dont want to sound like an idiot but you could get a columbia two speed for an extra up top gear.
  5. kellys29
    kellys29
    from spokane wa
    change it to drop in axles. old school was 50 merc or F100. today they run 9" axles.
    How do they do that? I am looking into this on a 40 rear, Any help would be great.
    Jeff
  6. Jimmy2car
    Jimmy2car
    from No. Cal
    1) Posi is possible- Hot Rod Works has it, or you can fit a "Lock Rite" yourself.
    2 Probably the highest is a 3.25 ratio without a Quick-change.
    3) You can replace the axles with new style by machine work to the carrier ***y, changing the side gears, changing the axle ends, etc. Hot Rod Works does all of this. They are a really good company and extremely helpful. Highly recommend
    Jim
  7. 1929CDAN
    1929CDAN
    Do a search for Quickchange information. I posted it a some time ago and has great info that you can use on your banjo with or without a quickchange.
  8. What year do you have? Different years different stuff available. What are you going to put it in?
    Charlie Stephens
  9. 38Chevy454
    38Chevy454
    Just as Jimmy2car said - go to Hot Rod Works. They will fix you up with everything you need. Great guys and excellent parts.
    http://www.hotrodworks.com/
  10. You can get a Winters QC with a locking differential that will take late 31 spline axles and work with Ford axle bells. By the time you get it all set up you will spend as much or more than the price of Winters package ***embly.
    Another option is to use the Hot Rod Works axle conversion kit that retains the stock brakes and spring perches.
  11. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Someone on here posted a thread on modifying the ends of the axle tubes to receive 9" axles. I forget who. Good info though.
  12. Mad Bomber
    Mad Bomber
    from Missouri
    Thanks for the info, Bomber
  13. stillrunners
    stillrunners
    from dallas
    know this doesn't fit....but does any one remember an artical spread on how to make the old banjo an IRS...like a Vette's....or was that a dream?
  14. 17dodgebros
    17dodgebros
    how do u fit the lock rite? anyone have pics?
  15. badshifter
    badshifter
    Post #38 shows how it's done.
    http://www.jalopyjournal.com/forum/showthread.php?t=586925&showall=1
  16. Work4it
    Work4it
    Does anyone have more information on fitting one of these? I have also heard "Goltrack" type can be used. It that is vague. There are some specifics missing.
    What size are the ring gears in our banjos? Mine is 1940 Ford and I want a posi, ain't afraid of machine work or welding.
