Technical OLD TOOLS
Discussion in 'Traditional Hot Rods' started by G.M.-TECH, Dec 26, 2024.
  1. G.M.-TECH
    G.M.-TECH
    I got a box of old tools when I bought a 36 5 window coupe. Could any help with the usage? I plan on rebuilding a merc flathead and these could be useful. Thanks for the help. image.jpg image.jpg image.jpg image.jpg image.jpg
  2. i7083
    i7083
    #3 looks like a ring groove cleaner.
    #4 &5 may be valve spring compressors.
    squirrel likes this.
  3. banjorear
    banjorear
    Last two pictures. All Power spring compressor that allows you to assemble that valve assembly with the guide and keeper as a unit. The last picture is a KD Tools valve guide remover. Once have removed the horseshoe clip, this tool pushes the guide assembly out of the top of the block. The first picture looks like a piston ring groove cleaner.
  4. #2 is also a valve spring compressor. JW
  5. number one is a piston groove cleaner also.
  6. Mr48chev
    1 and 3 are ring groove cleaners. 2 is a valve spring compressor commonly used on inline flathead engines. 4 is a valve spring compressor and 5 is the afore mentioned valve guide remover for flathead v8.
    Okie Pete and Tow Truck Tom like this.
  7. G.M.-TECH
    G.M.-TECH
    Thanks for all the help/info!
