Technical OLD undercoating removal
Discussion in 'The Hokey Ass Message Board' started by nmpontiac, Mar 28, 2015.
  1. nmpontiac
    nmpontiac
    from Taos, NM
    I'm working on a customer's '30 Plymouth and the wheel wells are really eaten up. I needed to replace at least that section and it was covered with old tar-based undercoat, and I s****ed off what I could but it still left quite a bit, especially in the area right next to the quarter panel. These particular cars were built with a complete wooden frame for the body and the body panels nailed on to the wooden frame with about a million little nails, so some panel repairs are a little more complicated than say my Model A - anyway I needed to get the undercoat off so I had clean metal to weld the patch panel to - I tried just about every solvent I had here (except the Brake-Kleen, a very bad choice for metal that's going to be welded) and nothing worked very well, so I ran over to NAPA and found some tar and bug remover in a spray can (Stoner Tarminator) and this with a steel bristle toothbrush style wire brush took it off nicely. The pics are of the p***enger side, which is still in need of repair, and the driver's side area that I'm currently working on - the side of the wheel well next to the quarter is as it came out using the spray and brush, the other side I've cleaned up with a 2" surface conditioning pad. Just thought this might help others. DSCN1222.JPG DSCN1223.JPG
  2. brigrat
    brigrat
    from Wa.St.
    I believe old under coating is petroleum based, I found a can of elbow grease (the big can) and a gallon of gas worked as well as anything. Warning gas is flammable so don't try this at home..............
  3. 55Caddy62
    55Caddy62
    Kerosene works well and is much safer than gasoline. Diesel works too.
  4. Dangerous Dan
    Dangerous Dan
    images.jpg I stripped my whole frame, and under body where I need to weld patch panels with an old fashioned paint s****er and a wire wheel on my grinder.
  5. RmK57
    RmK57
    Heat with a propane torch until soft then s****. Comes off pretty easy, then use solvent on a rag to wipe off excess.
    Wheel wells, floor pans works fine I wouldn't do fenders or any
    Thinner metal that could warp.
    tb33anda3rd likes this.
  6. Hot Rod Nut
    Hot Rod Nut
    I use a small torch, the type for soldering copper pipes, and a putty knife. Just heat it up and peel it off.
  7. HOTRODPRIMER
    HOTRODPRIMER
    Putty knives,pull s****ers and wire wheels and brushes,I would avoid gas & torches,sure don't want a accident. HRP
  8. oldsjoe
    oldsjoe
    I stripped the entire undercarriage of a sixty's GM big car with an electric heat gun and multiple type's of s****ers. Then the residue was cleaned off with a rag and reducer. Took me about a week of evenings after work. Results were great!
  9. J. A. Miller
    J. A. Miller
    from Central NY
    ^^^ Heat gun and s****er works well.
  10. donno
    donno
    Roger on the heat gun, have done about 6 vehicles and it works great.
  11. Camsore
    Camsore
    from Las Vegas
    Heat gun and s****er works good
  12. raymay
    raymay
    oldsjoe nailed it. This is the best method I have found so far. Did this on parts of my 56 and last year on a 32 Ford body. It does take time and lots of muscle but you should be satisfied with the results.
    If you have other areas where you might want to re-apply some coating, the heat gun keeps it soft and easy to work with. I did this under a right side repaired area of the 32 roof and it looked just like the coating on the left side making the repair look invisible and adding some sound deadening.
  13. tb33anda3rd
    tb33anda3rd
    i have used both the propane torch and heat gun with good results. too hot and it will smear and leave a residue, too cool and it will take too long. warm the tip of the s****er and keep the heat an inch ahead of the s****er. push faster if it gets too soft.
  14. pdq67
    pdq67
    Probably can't get it unless it is in a "gel" paint stripper.
    Methylene Chloride!
    Stuff will wipe the "smile" off Mr. Clean's face!
    pdq67
  15. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    heat gun,s****r,wipe down the rest.....
