Older Weiand Air Cleaner
Discussion in 'The Hokey Ass Message Board' started by Hdonlybob, Jan 26, 2011.
  1. Hdonlybob
    Hdonlybob
    Just picked up this older Weiand air cleaner off FleeBay.......and curious.
    Did it originally fasten to the carb with the large radiator clamp??? If not, what was used..
    Thanks much,
    Bob :D
  2. Edelbroke
    Edelbroke
    What's the base look like? It may have had a flat center bar like the Edelbrock pro flows use to hold the base on the carb center stud and the lid would bolt to the base.
  3. Hdonlybob
    Hdonlybob
    Here is a pic of the base.....
  4. Edelbroke
    Edelbroke
    It probably just fits snug on the carb, if it doesnt, bend the ring in a little so it does.
    I had 2 on a tunnel ram that just pushed on the carbs with no attatching hardware.
  5. 31fordV860
    31fordV860
    Very Cool...
  6. 65 Imp SS
    65 Imp SS
    from central mn
    Edelbroke is correct " may have had a flat center bar like the Edelbrock pro flows use to hold the base on the carb center stud and the lid would bolt to the base. "
    When Holley took over weiand they had dropped the Weiand and Holley made it till around 2008 when it was also discountinued Holley's part #120-147 Here is a link to a Holley 2008 catalog
    http://www.holley.com/data/Catalogs/Dress Up.pdf
    If I can find mine (holley) and if I can figure how to i'll try and post a pic of that attachment bar..
  7. 65 Imp SS
    65 Imp SS
    from central mn
  8. Hdonlybob
    Hdonlybob
    Thanks.....that attachment should be easy to make... !!
  9. chevyman55
    chevyman55
    I have an air cleaner like the one shown in the picture purchased from ebay. What year was it made and current cost
  10. Do an intro in the appropriate section if you expect to get any respect around this joint! http://www.jalopyjournal.com/forum/showthread.php?t=44274
  11. It had a bar that mounted across the base opening that stayed beneath the top.
  12. Deuces
    Deuces
    Looks like an '80's air cleaner...
  13. '70s not worth squat unless you're a street beast enthusiast.
    Uh have we met? I see one post a question. Who are ya and what are you about?
