olds 324 mains
Discussion in 'The Hokey Ass Message Board' started by Oldsmobucket, Aug 30, 2012.
  1. Oldsmobucket
    Oldsmobucket
    this might be a really stupid question but i am going to ask anyway. I am about to put in the crank on my 55 olds 324, do the main bearings go tang to tang? just want to make sure before i do some thing wrong. thanks for any help
  2. Oldsmobucket
    Oldsmobucket
    Anybody?
  3. JohnEvans
    JohnEvans
    from Phoenix AZ
    YES ,never seen a engine that had locating tangs on bearing that they were not on the same side.
  4. Oldsmobucket
    Oldsmobucket
    Thanks just wanted to make sure
  5. Dan Timberlake
    Dan Timberlake
    BMW cars and bikes at least up until the 80s or so have the bearing tangs opposite each other. That's the only one I can think of.
    Attached should be a picture of a BMW mc rod off EBAY. I had to brutalize the brightness to make the bearing tang visible. Not there are dowels locating the cap and rod.
    Before installing the crank it I'd install the main caps without bearings and torque them, then use a bore gage to check for size, taper and cap shift. At least feel the parting line between cap and block for shift/overhang. If the caps are on backwards I'd expect a very feel-able step/overhang. I'd guess only 3 or 4 of them could be installed 180. Doesn;t the rear main have a seal built into it?
    Was it a running engine? sometimes folks take a cap or caps from another engine, and they will be way wrong. Another reason to check the bores out with a bore gage
  6. F&J
    F&J
    True. The 324 main caps are all factory numbered, but I forget which way the number is facing. But yes, the caps won't fit right at all if they are backwards, at least not all of them could.
    Also, check your crank for cracks where the 90* notches are on the throws. Mine was cracked 1955 324
  7. GOATROPER02
    GOATROPER02
    from OHIO
  8. bt34
    bt34
    ..and use the neoprene rear main seal..Better than the old dog turd style..
    (Egge Machine in LA)
  9. Oldsmobucket
    Oldsmobucket
    Thanks for the help guys. I got a new rear seal from goatroper
