Olds 394 timing problem?
Discussion in 'The Hokey Ass Message Board' started by SweOlds, Apr 25, 2012.
  1. SweOlds
    SweOlds
    from Sweden
    Hello!
    I'm rebuilding my first engine (oldsmobile 394 cui from 1960).
    Bought an deluxe rebuild kit that also included new camshaft (from a starfire), timing chain and sprockets.
    Now to the problem, I can't seem to get the marks on the sprockets to line up.
    The cylinder #1 is in TDC and I know that the crank sprocket marking should be at 12 o clock while the cam sprocket marking should be at 6 o clock, right?
    It doesn't mather how I install the sprockets, the marks will always have a little distance. I can't get the cam sprocket to get at exactly 6 o clock.
    Is this how it is meant to be or have I done something wrong?
    How much will this do for the timing, will the engine run correctly?
    Maybe it has something to do with the swap to a starfire camshaft?
    I also noticed that the marks on the old sprockets were bigger than on the new ones.
    Pictures of the markings:
    http://oi45.tinypic.com/2qiplcj.jpg
    http://oi48.tinypic.com/rh66tv.jpg (red line where it's supposed to be??)
    Greetings,
    Andreas from Sweden
  2. Andreas,
    I always line the marks up, to start with. I don't have a book that goes that far back so I can't give you an accurate answer but I always line the marks up.
    Let me ask you this when the marks are lined up is it before top dead center, maybe the starfire cam is advance from the factory.
    Will the marks line up at 12 oclock and 12 oclock?
    OK I looked at your pics and my timming set from my 394. Your marks are in the right place. if your marks don't line up exactly then line up the valley on the top sproket with the tooth on the bottom sproket.
    Like this:
  3. SweOlds
    SweOlds
    from Sweden
    I will try the 12 o clock and 12 o clock, returning with an answer soon :).
    The problem is when I put the chain on, it's like the chain won't let me have the sprockets to line up. Before the chain is on, there is no problem. But the chain has the same number of links as the old one.
  4. I am sending goatroper02 a PM in case I have given you bad information.
    My timming set is gennie GM and my marks are identical you yours. One thing not to worry about is where the piston is in its travel unless you are degreeing the cam shaft in which case you are going to end up using an offset key anyway.
  5. GOATROPER02
    GOATROPER02
    from OHIO
    Andreas, you are correct in the pics
    There was acually a tool from GM for these Olds that makes it easier to see when aligning the marks......tool is rare....I dont even have one
    We always use a degree wheel when installing a cam.....But that is our backround...I understand not everyone can
    Tony
  6. SweOlds
    SweOlds
    from Sweden
    Thanks for all help!
    I could turn the crankshaft just a little bit more without having the piston to start move back down, I think that solved the problem.
    This is a picture of how it looks now:
    http://oi45.tinypic.com/2zi54pv.jpg
    I think it's better than before, do you think it's good enough?
    If it is, I will start mount the timing cover and oil pan later :).
    Again, thanks for all help and information :)
  7. BJR
    BJR
    That upper timing mark is stamped off a little, it should be centered in the valley between the two teeth.
  8. bobss396
    bobss396
    Looks like it was mis- marked by a hair. You could contact the manufacturer, maybe they'll send you a new piece.. for peace of mind.
    Bob
  9. GOATROPER02
    GOATROPER02
    from OHIO
    They are all like this....I gave explanation a couple posts ago
    Tony
  10. bobss396
    bobss396
    I must have missed it and don't recall running into the issue on my 394 when I was putting it back together.
    Bob
  11. Paul
    Paul
    Editor
    that looks better
  12. SweOlds
    SweOlds
    from Sweden
    Does anyone know the correct ft/lbs for the three camshaft sprocket bolts?
    I can't find it in the service manual for the engine and I don't want to break the bolts or tighten them too loose :/
  13. rjaustin421
    rjaustin421
    I feel a foolproof way to check if a cam is in time is to check what is often called the rock over. That is when the piston is moving up and chasing the exhaust valve. Just before the piston comes all the way up the exhaust will close and just as the piston starts down again the intake begins to open. The valves should be "rocking" open & closed if you move the crank back & forth bringing the piston up and down from the deck.
    If you are off a tooth (or teeth) the valves will not be remotely close to rocking. Even with a heavy overlap cam the pistons and valves will be doing this dance. With a bit of creative thinking you can move the cam timing around in the rockover position and find the correct timing point.
    <!-- / message -->
    Should you be off just a little, it would be nice to see what is available for offsetting the sprockets to get the rock over closer. It has been many years since I worked on a first generation OHV Olds & I cannot recall if the sprockets were both keyed.<!-- sig --><!-- / message --><!-- sig -->
  14. bobss396
    bobss396
    What size are the bolts? I'll look tonight in my Motors Manual, but I'm sure we can come up with a good torque for you.
    Bob
  15. Paul
    Paul
    Editor
    14-22 lbs
  16. SweOlds
    SweOlds
    from Sweden
    The bolts are 1/2.
  17. SweOlds
    SweOlds
    from Sweden
    Ah thanks :)
  18. bobss396
    bobss396
    That sounds about right, good find. My guess is that they're probably a 5/16-24 thread.
    I'm usually pretty good at coming up with torque specs for just about anything, but when I do help someone out, I usually get a rash of posts from the "experts" telling me I'm wrong. My calculations come up with 16-21 ft-lbs.
    Bob
  19. Paul
    Paul
    Editor
    that was taken from my '59 shop manual, actually listed as fuel pump eccentric bolts
  20. bobss396
    bobss396
    If the eccentric runs off the cam gear (forget.. had my olds 394 apart many moons ago..) the info is correct.
    Bob
