OLDS 394 with 6X2 setup?????
Discussion in 'The Hokey Ass Message Board' started by 6deucecaddy, Nov 27, 2007.
  1. 6deucecaddy
    6deucecaddy
    What kind of carbs would be best to run on my 6X2 Edelbrock Log Intake? Im installing them on my 394 OLDS. Holleys, Strombergs, 94, 48, 97???? Is one better than another? :confused: Which one are more reliable or should I say less troublesome. I know somebody that will sell me some Holley 94s. Should I buy them? Help a fellow HAMBER out please. Im excited that I bought the 6x2 but not to excited to pay $1000+ in carbs. But I guess thats the price you pay if you want to look cool.:D
  2. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    If you want to really run six functioning carbs....I recommend that you get your hands on six good rebuildable carbs and rebuild them yourself...You are going to want to know those carbs inside and out.....I run the 94's and like them, they all will work thou.....A hotrod to me is all about Function, looking kool is a by-product of that.....If it looks fast it should be fast.........Their are alot of hotrods running around that are fake, that have lost the true meaning of what a hotrod once was ....But thats my opinion.........Set that puppy up and run all six, pay your dues setting it up...and she will run like a rapped ape..........Goodluck Littleman
    Kreepea_1 likes this.
  3. Louie S.
    Louie S.
    I agree with Littleman on this one, and i wouldn't let anyone talk you into blocking any of them off. Blocking carbs off is as wrong as two boys fuckin!:eek:
  4. Paul
    Paul
    Editor
    pretty sure Mike Soldano runs six large logo 97s
    all functional, says when they all open up it's like a freight train
    geuss that's a good thing :)
  5. 6deucecaddy
    6deucecaddy
    I agree. I want to make my intake as functional as possible. I want to run all 6. Not like some guys that run 2 and block off 4.:rolleyes: If I run Holley 94's, is there a certain kind or year?
  6. aerorocket
    aerorocket
    from N.E. P.A.
    Littleman I agee with you 100%. Hotrods are about function, if it don't go chrome it.
  7. kustombuilder
    kustombuilder
    from Novi, MI
    i'll bet it will be a little cheaper in the long run to run the Rochester 2GC carbs. they are cheaper to pick up as cores and parts are easy to get at just about any parts store. GM used em in tri-power setups back when they used to do cool shit from the factory.
  8. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I'm not big on nonfunctional carburetors. Six 97s on a nearly 400 cubic inch engine should be streetable, especially if you run progressive linkage and start out on the center carb on each side.
  9. langy
    langy
    I'm running 6 x 94's on my 394 and a progressive linkage which was a bitch to get working correctly, Mine runs on the 2 centre carbs and the others come in as required as my linkage is completely adjustable.
  10. Derek Mitchell
    Derek Mitchell
    Form follows function.
    Simple rule to live by. Make them all work. I would go with 94s, thats alot of motor.
  11. 6deucecaddy
    6deucecaddy
    Do you have any pictures of what your 6X2 setup looks like?
  12. ian
    ian
    I've got four 94's complete with all the rebuild parts you'll need. You'd just have to acquire two more and two more rebuild kits. I'm in Gardena near Long Beach. Shoot me a PM if you're interested. Thanks.
    Ian
  13. cheaterslick
    cheaterslick
    Here's mine, 394, six 97s on my own log intake
  14. hell bent
    hell bent
    my buddy has a milk crate full of 94s that he is selling pm me i can get you in contact with him
  15. 6deucecaddy
    6deucecaddy
    That thing is pretty damn sweet!!!!
  16. I am running six 94s on my 371. I agree with everyone, you have to run all six. It may take some playing around but it will be worth it.
  17. superjunkman
    superjunkman
    from Austin, TX
    I posted a similar question about my 324. Littleman convinced me to give the solid linkage (6x2 Gotha) at least a fair shake. I'll screw around with it for a while and see if I like it before trying to rig up some super complicated progressive linkage.
  18. Terry O
    Terry O
    94's were made by 4 different companies between 1936 and 1957.
    The problem is they all had different CFM ratings ( between 135 and 185 )
    Venturi's were different sizes too.
    It's real important that you start out with a matched set before rebuilding and enter the wonderful world of power valves!
    Terry
  19. I like my beer and carbs the same, six at a time!
  20. dickster27
    dickster27
    from Texas
    Wow, looks like you may have a terrible vacuum leak when you fire it.
  21. J Man
    J Man
    from Angola, IN
    I have a Offy 6x2 for Olds that is drilled for 3 bolt carbs so I will most likely use Holley carbs on it. I need a Nailhead 6x2 for one of my projects, I would probibly use Rochesters n it if I can find 6 of them.
  22. langy
    langy
    Only this one without the linkage, I will try and get one of the progressive linkage this weekend.
