OLDS 442 HOOD-LUM
Discussion in 'Off Topic Hot Rods & Customs' started by Bandit Billy, May 7, 2024.
  1. Corn Fed
    Corn Fed
    You big city folks with your Boston and Aerosmith. Out here in the sticks I prefer good old Country and Western.
    TRAVLR, Sharpone, Sancho and 2 others like this.
  2. Bandit Billy
    Bandit Billy
    3 pedals,
    4 gears,
    8 tracks,
    Adds up to a good time.
    loudbang, Tim, Corn Fed and 3 others like this.
  3. Bandit Billy
    Bandit Billy
  4. Deuces
    Deuces
  5. oldsjoe
    oldsjoe
    Billy you do excellent work. I love your car I have a 68 442 Holiday coupe owned since 1977 it too has the parchment/pearl interior 4 speed 455 with 3:91 posi rear and a gear vendors O/D . I drive it all over many many road trips over the years. Put together a 68 Cutl*** convertible for my wife many years ago red with Parchment/Pearl interior white top. 455 with a turbo 400 and a moon gear in the rear. Car was originally a 350 2 speed I never got around to installing a posi once the gas prices went crazy I just left it alone. It's a pig outta the hole but top end is fun just takes awhile to get there. Also have a 67 Delmont 88 convertible Dad bought new it's Gold with Parchment interior white top. They are all fun to drive and show their age bumps and bruises but we drive them as much as we can. Joe
    Sharpone, Deuces and Bandit Billy like this.
  6. Bandit Billy
    Bandit Billy
    @oldsjoe that sounds like a nice stable! I have always played wit the idea of a GV for my Olds. Around town it is fine but 70-75 on the freeway is way over 3500 on the tach and my gas gauge takes a nose dive! I run 3:55's, one of my favorite around town gears but that gear vendor sure is a temptation.
    Feel free to post up your Olds pics here. I don't see enough of them.
    Sharpone, SS327 and Deuces like this.
  7. Bandit Billy
    Bandit Billy
    I took the Olds for a drive Sunday and I braked down. Literally! Front discs locked up, red hot, smoke pouring out of the fenders, great!
    I suspected the line locs but it looks like the calipers just froze up and the M/C is a bit rusty. New parts coming.
    while I’m at it I’ll flush the old fluid and purge the lines. I did brakes in 2009, that wasn’t a ton of miles back. Rats shoes still look fresh.
    you like my “rubber” under coating? Lots of tires have their all for that rust proof coating.
    I took the routers in for turning just in case they warped after getting that hot. New pads came with the calipers.
    I got a new proportioning valve with the M/C. Should be here tomorrow or Wednesday from CPP so I can re***emble.
    I put 69 brakes on the front end when I first built the car 27 years ago. It had drums up front originally. 68 calipers were a PITA, the single piston calipers are much easier to source as they fit just about everything GM built for over a decade.
  8. oldsjoe
    oldsjoe
    Always good to refresh the undercoating in the wheel wells a few times a year! Keeps the senses working!! Joe
  9. Bandit Billy
    Bandit Billy
    One of my buddies suggested I remove the line locs, I said "where's the fun in that?"
    swade41, Sharpone and porkshop like this.
  10. oldsjoe
    oldsjoe
    I agree Billy what the heck it's like the big FUN ****on! Joe
    Sharpone, porkshop and Bandit Billy like this.
  11. oldsjoe
    oldsjoe
    Not to hijack your post here's one of my Oldsmobile's. Joe upload_2025-3-11_17-11-15.jpeg
  12. Bandit Billy
    Bandit Billy
    Oh, that aint hijackin! It's more than welcome. Looks like you got a wrinkle in that front fender or is that the light?
  13. Bandit Billy
    Bandit Billy
    Hmmm. I don’t remember bottoming out that oil pan. Glad the drain plug wasn’t on the bottom!
    It doesn’t leak. Which, since it’s an Oldsmobile is saying something. Everything else leaks. I’d like to have been in the QC dept at GM and had a word with guy that thought 28 valve cover bolts should keep it from leaking Not!
  14. DDDenny
    Those would be fight'n words at an Australian burnout contest.
  15. Bandit Billy
    Bandit Billy
    The thought never crossed my mind.
    Sharpone, porkshop and Deuces like this.
  16. oldsjoe
    oldsjoe
    Thanks Billy. Must be the light it doesn't have any fender damage. Joe
    Sharpone and Bandit Billy like this.
  17. chevy57dude
    chevy57dude
    Billy - you whacked that pan pretty hard!
    @oldsjoe, that is sinister looking.
  18. Bandit Billy
    Bandit Billy
    You think I would have felt that? I gave the QA-1s a few turns, bring the nose up a bit.
  19. Bandit Billy
    Bandit Billy
    Summit sent two right calipers the first time, and for the wrong application (thick truck rotors). Correct ones should up today.
    $200 for a pair of red powder coat calipers with pads/hardware/banjo bolts and coppers.
    Long wait but it’s raining cats and dogs out there anyway. Besides, the M/C is on back order. Seriously? You’d think the car was 100 years old. I’m just happy there are still parts available.
  20. Bandit Billy
    Bandit Billy
    Here's a cool line loc mounting idea. I did this in 2009 when I did the brakes last. I used a GM proportioning valve bracket on the right side of the M/C to hold it. Looks like a factory option…ish.
    I went through a gravel guard phase when I built the olds, even the ****** cooler lines are covered. Don’t judge.
  21. oldsjoe
    oldsjoe
    Billy I've looed at the picture of the line loc set up and that is very clean. But I can only find one line that would go to the master cylinder, or was the rear one removed for accessibility? Just curious. Joe
    Bandit Billy and porkshop like this.
  22. Bandit Billy
    Bandit Billy
    One line leaves the front reservoir of the M/C and feeds the line locs. The out put line from the line loc feeds the proportioning valve, and from there the two front brake lines are routed like normal.
    I did notice last night while taking everything apart (again) to correct a leak, that I did have to cut a portion of the extra P/V bracket off to clear the master as it was not meant to be turned around backward like that.
    Deuces and porkshop like this.
  23. Bandit Billy
    Bandit Billy
    Waiting for the M/C to show up. Decided to give the diff cover a little sand and buff. That’s normal right? I didn’t get carried away, this is not a show car, just a nice driver. Just the flats and the ribs. No paint fill, just compound. Traditional.
    Sharpone, swade41, porkshop and 3 others like this.
  24. Deuces
    Deuces
    Can anyone buy repops of those W-27 rear covers????... Those are cool...:cool:
  25. Bandit Billy
    Bandit Billy
    Yes, anyway they were 20 years ago. They only fit Olds axles though. Chevy never made a cool cover, not Pontiac or Buick (I think). No idea why. Yes, they are very cool!
  26. Bandit Billy
    Bandit Billy
    Joe, do you know if the header panel, that panel above the windshield on my 68 Olds that the soft top closes against, is it the same as Chevelle/GTO? It is upholstered from the factory, and I never liked it. Camaros have a SS piece that looks much nicer. I found a Chevelle piece online, new, I was thinking ab out buying it, chroming it and installing it. That is a lot of expense if it won't fit. Any idea if it will work?
  27. Bandit Billy
    Bandit Billy
    I hope that master cylinder shows up soon. I’m running out of things to do.
    The olds has polished aluminum valve covers, a polished aluminum rear diff cover and now a polished ****** pan.
    Again, just the ribs and the flat logo area.
    I also made some braces to keep the air dam from vibrating. A couple pieces of flat stock, welded to a couple thick washers at the ends. The air dam has holes already that lined up nicely with the sway bar brackets.
    It has been years since the olds was on the lift. Nice to have the opportunity to freshen her up “down under”.
  28. Tim_with_a_T
    Tim_with_a_T
    That's a clean machine, from all angles. I'd expect nothing less from you lol.
  29. 6sally6
    6sally6
    I can't see it....(must be under that B&M skid plate)
    6sally6 :p:p
  30. Bandit Billy
    Bandit Billy
    They say cleanliness is next to godliness, so I have that going for me...which is nice.
