Olds casting number help
Discussion in 'The Hokey Ass Message Board' started by jerseytrumpet, Apr 28, 2006.
  1. jerseytrumpet
    jerseytrumpet
    from NJ
    I am trying figure out what engine i have in theis '50 olds that i bought. the body is a 1950. the heads have a number 7 on the center exhaust port, which i think is a 1954. the problem number is the block. it has the number 563922 on the bellhousing on the p***enger side top. does anybody know what block this is? i measured the bore which is 4 inches. the stroke is approx. 3.5 inches. is this a 324 block that is punched out .030-.040? or is it a 371? hopefully somebody out there can give me a direction to go in. thanks
  2. 5window
    5window
    You might thry the American Automobile Casting Numbers Club.They're into stuff like this.Their web site is www.aacncclub.com
  3. seymour
    seymour
    from PNW
    Look at the left side of the block, between the exhaust ports, there's a flat spot with the engine number stamped in.
    Starting #'s:
    1950: 8A-194001
    1951: 8C-1001
    1952: R-1001
    1953: R-215001
    1954: V-1001
    Head Casting #'s:
    early 303: #2
    1954: #7
    1955: #8
    1956: #10
    Cubes Bore Stroke
    303 3.750 3.4375
    324 3.875 3.4375
    371 4.000 3.6875
    394 4.125 3.6875
  4. Paul
    Paul
    Editor
    568922 is a 324 block
  5. jerseytrumpet
    jerseytrumpet
    from NJ
    I checked. it's a 3 not an 8. Thanks for your reply.
  6. jerseytrumpet
    jerseytrumpet
    from NJ
    i think i have a match with the #7 heads. The numbers on the driver side deck are V2####. i beleive i have a 54 324 punched out to a 4 inch bore. Thanks for all of your help, I really wanna run this engine and not "just drop a 350 in it", like all the sheep keep telling me to do.
  7. jerseytrumpet
    jerseytrumpet
    from NJ
    by the way, is that Bukowski as your icon? Nice.
  8. Paul
    Paul
    Editor
    I'm not doubting you,
    it's not what I find in my books or on line..?
    yes it is Puke-kowski
    here's a link to some #s
  9. HEATHEN
    HEATHEN
    from SIDNEY, NY
    It sounds like a 324 bored .125 over with standard size 371 pistons in it, making it a 345. Since the 371 had a taller deck height to componsate for the longer stroke, the compression height stayed the same as the 324 piston.
