olds engine help
Discussion in 'The Hokey Ass Message Board' started by lurch423, Oct 26, 2010.
  1. lurch423
    lurch423
    i know nothing about olds engines im gonna rebuild a 455 its a 75 model it has j heads . i want a good performance engine its going in a 58 anglia cars been a old drag car i want somthing that has a good noticable " thump " while idling.gonna be a street strip car heres my questions.
    im looking at a lunati voodoo cam its a 227/233 @ .50 510/522 lift is this a good cam for a 455 do you think i will hafta run a stall any other ideas on a cam ?
    i think with the cam i wanna run ill hafta have the heads fixed for adj. valve train should i s**** the j heads for somthing else are they any olds heads that are stud mount ?
    oil pump stock or high volume ? its gonna be a hyd motor
    any other weak parts i need to spend extra money on i know the rockers are one i plan on using a engine kit proubly a speed pro any info is appreciated
  2. squirrel
    A cam with that much duration will want a 2500-3000 stall converter
    Sorry I can't answer your other questions, I haven't worked on any hot rodded late model olds engines.
  3. Vandy
    Vandy
    from L.A. Ca
    To convert your heads is easy, all you need is a drill press. Just drill the rocker mount holes to tap drill size for 7/16 X 14 and tap the threads. You need SBC adjustable guide plates and install the studs and guild plates, then use SBF roller rockers. The cam will work fine. Install SI stainless valves and use springs for the cam. I use the hi volume pump and no restrictors. Use the full grooved main set bearings and run the crank on the low side with 20X50 oil. I saw a tunnel ram on Performance boat for sale.
    Van
  4. lowkroozer
    lowkroozer
    lurch423 Ross racing engines ,specialize in Olds engines .They are in NilesOhio--Phone330 544 4466 The owner is a HAMB member Goatroper02 is what he goes by. He can fix you right up
  5. jandersonheads
    jandersonheads
    dude, you are in TN. Call Joe Mondello. He's in your neck of the woods
  6. plymouth1952
    plymouth1952
    Joe is a hell of a guy ! I used to see him at Paso years ago. he has forgot more then most folks know about olds motors.
  7. chevy57dude
    chevy57dude
    If you plan on twisting that engine over 5000rpm, it would be a good idea to get the block modified to priority oiling. This way the crank gets oil 1st, then the top end. Mondello and **** Miller Racing are the big players for Oldsmobile engines.
  8. joe_padavano
    joe_padavano
    Others have this covered, but the J heads are not your best choice. If you plan to do a LOT of porting, they'll be fine, but in stock form they are restrictive smog heads. The most cost effective solution is probably E-brocks.
  9. lurch423
    lurch423
    yea id like to s**** the j heads but i dont think i can afford edelbrocks right now any other ideas on stock iron heads to use
  10. "C" heads work well and are usually fairly easy to find.
  11. oldspert
    oldspert
    from Texas
    Olds C heads come in two varieties, Big valve and small valve. Basically both are good if you have larger valves installed in the small valve heads. Do some pocket porting and relieve the exhaust ports by removing the smog bumps. All Olds heads have them but most do not have them drilled and tapped. Also look for E, K, or K with a small a. Some of the harder to find, and very pricey, are D, F, H. These are prized by restorers so if you find a set cheap, buy them, sell them and finance your entire engine build with the proceeds.
    Try to stay around 9.0 to 1 compression for street motors. If you get Edelbrock heads, you can get by with around 10 to 1.
    Olds 455's are noted for torque and in an Anglia's short wheelbase, it will be very easy to lose it.
