Olds experts...I need turn signal help.
Discussion in 'The Hokey Ass Message Board' started by JK, Jul 14, 2012.
  1. I need to rebuild my signals. I have the wheel off and I can see the signal cam and the cable that goes down to the switch. My switch is wired correctly and works. Honestly, I think I'm missing some parts and can't figure out to get the damn thing apart to replace parts (even if I could fine replacements). Here's some pics of what I'm working with. What am I missing? The column has "62 starfire" written on it if that matters.
  2. Maybe Joe Padavano can help. Try to contact him here
  3. That would be nice but he hasn't had any activity in almost a year.
  4. Dane
    Dane
    from Soquel, CA
  5. tommy
    tommy
  6. justinj
    justinj
    There is a diagram for that steering column in either the 61 or 62 Olds service manual.
    You can download a complete service manual for that vehicle at 'wild about cars' wildaboutcarsonline.com for free. You need to sign up then select "The Library" and follow the links.
    It's likely in the '61 manual as the '62 manual is basically just a supplement.
  7. Here's part 2. I just got back from a shop here in town that has a lot of olds stuff. I looked through his collection and found a 64 jetfire that had my wheel on it. I didn't think to check the signal part though. The signal plug on mine is a triangle shape like the 63-66 Chevy full size cars, not the stand up kind. So, I think I have a 64 starfire tilt column. Thanks for the link Justin, I'll check it out.
  8. 24riverview
    24riverview
    Looks like it but no, recently worked on a 59 Olds (with stock column) that had a turn signal switch like that.
