Here’s some shots of an engine for a project. I need to add a water pump and starter to it but do not know the year of the block. It’s a 394 (supposedly) and I was told the block was early 60’s but I haven’t found any water pump for it yet. r Sent from my iPhone using H.A.M.B.
Definitely 394, marine timing cover looks to bolt up like the '59-'62 iron car cover. Engine number is stamped on the head, at top of center exhaust port flange, hopefully those are the original heads..
Ok, lots of smart-***ed comments (which I don’t mind [emoji16]), the heads are not original but you can drive a medium sized car through the ports so they are staying. The beneficial information was that it’s a marine timing cover, so I guess I’ll need a car timing cover too. Don’t worry, I’ve got the rest of the engine too. Anyone have a car timing cover they would part with? r Sent from my iPhone using H.A.M.B.
And none of you sharp-eyed people noticed the sheet metal intakes.... You’re slipping. r Sent from my iPhone using H.A.M.B.
