Olds guys....'26 or '49 ?? Need feedback.
Discussion in 'The Hokey Ass Message Board' started by Barn Hunter, Oct 18, 2013.
  1. Barn Hunter
    Barn Hunter
    I found a couple of Oldsmobiles for sale and I'm torn. A '26 2 door sedan and a '49 2 door fastback. The 26 is 95% complete and 95% rust free with a '46 Stude 6 cyl. and is 3500. The 49 has no engine/trans/interior, has a little more rust and is about 2500. Would like to know the goods and bads about these. Some obvious is the amount of wood in the 26. The frame looks much heavier than a T and it's parallel leaf front and back. They're just so different but both are cool.
      282 KB
      415.8 KB
  2. wheel28
    wheel28
    Easy answer both. For those prices you will be kicking yourself if one gets away.
    I would build the 49 first .
    Will
  3. Dago 88
    Dago 88
    What he said ^^^^. I would love a '49 fastback, but the '26 looks cool also.
  4. The '49, hands down!...................or both.
  5. BuckeyeBuicks
    BuckeyeBuicks
    from ohio
    Buy them both, build the 26 and send me the 49 to Ohio, I just had a birthday and nobody got me a damn thing! If that doesn't sound to good to you, buy both and flip to 26 and use the profit to build that 49 with a J-2 Olds and a hydro. Love that Olds body style!
  6. scrap metal 48
    scrap metal 48
    49 without a doubt...
  7. papajohn
    papajohn
    If you can only swing one, get the 49 and give the lead to the 26 to a buddy.
    Otherwise get both.
    Posted using a number two pencil on a paper napkin.
  8. bgaro
    bgaro
    i'd be all over the '26. personal preference i guess, ask yourself " do i want a hot rod or a custom?"
  9. 327Eric
    327Eric
    get the 49. cheaper to build
  10. NickJT
    NickJT
    from S.E. PA
    I was born in '49 so I need a '49 something and that would be an excellent choice.
  11. Barn Hunter
    Barn Hunter
    The whole front cap to the 49 is rust free, just dis***embled....you guys are swaying me that way. Would be a neat cruiser.
      415.5 KB
  12. HOTRODPRIMER
    HOTRODPRIMER
    I would buy the Olds!:D
    I like the idea of the '26,,it's considerably rarer of the two cars and in a sea of Fords and Chevys you don't see many,especially here in the South. HRP
  13. wbrw32
    wbrw32
    Count yourself lucky,,,My birthday was last week and all I got(from my girlfriend) was a piece and a pair of stretch socks,,,Both to large..
  14. raidmagic
    raidmagic
  15. Russ B
    Russ B
    The '26 is a dare to be different choice. The '49 is a traditional hot rodder favorite choice. It is your call. Which one speaks to you? Which one inspires YOU? Which one realistically would you drive and enjoy? Building either will take time, dedication, and $$$. Just pick one and stick with it to the finish.
  16. pitman
    pitman
    Tough to call, I'd bet you would enjoy cruising in the '49
    esp as the bodywork and paint progress. Even primed it will
    look killer!
  17. Fat47
    Fat47
    As mentioned above, buy them both and flip one of them. Which depends on how much time you want to spend on the build and what you want to do with it. 26 will take longer and will not be as comfortable if you intend to put any long distance miles on it. 49 sedanettes are also fairly rare, but they make great cruisers. You are also likely to find more knowledge/info on building the 49 here on HAMB and a bigger selection of parts.
  18. You're not going to flip for much of a profit at that buy in.
    The '49 will be the easier build, it shares the body shell with Chevrolet so rubber, gl***, some patch panels exist for it, there are later rearends that will bolt right in, the front suspension and brakes will be a little harder to update but not out of the realm of possibility.
  19. belair
    belair
    49 -no contest
  20. Model T1
    Model T1
    As much as I love the older cars I'd grab the 49 Olds and build a nice driver.
  21. If the wood is solid (easy way to tell is that the doors fit right, don't sag, and close tight) and none of the hard to find stuff is missing off of it, I'd want the '26. Would like to see pics of the Stude 6 swap. That said, the '49 will cost less to build and you can be driving it sooner. Lower center of gravity and more aerodynamic shape will be better for cruising on the Interstate. More boxy shape of a body that was never intended to run 70 plus mph will translate into more wind noise, and a flat vertical windshield will give you lots of glare from the headlights of cars behind you. That's why people used to install those little window shades on the rear window.
  22. 56don
    56don
    I would personally prefer the 26 for myself, but if you are going to rod one, I would think the 49 would be easier, cheaper and cooler when finished. A 26 Olds is more of a restorer's material I think.
    I fell in love with this one at a recent car show..
  23. mr.chevrolet
    mr.chevrolet
    even though i like Oldsmobiles, i want to know about that poncho in front of the 26.
  24. Barn Hunter
    Barn Hunter
    There's really nothing missing to speak of. It has a Model A headlight bar and headlights. The wood needs to be at least partly redone and I imagine it would be a major chore to replace it all with steel. What's cool is that it has pull down shades on all 4 side windows...didn't see one for the back window.
    It's a 67 GTO with an incorrect motor and it's 12 G's.
  25. Barn Hunter
    Barn Hunter
    This is sweet. It looks chopped and I'm not up to that right now...but I like it. I'd definitely do skirts and a louvered hood.
  26. Johnunit
    Johnunit
    from Toronto
    I agree with other people saying it's about what you want. One is hot rod material, the other is custom material.
  27. unkledaddy
    unkledaddy
    '49 all the way.
  28. clubcoupe37
    clubcoupe37
    i love that '26, matter of taste but i would also be all over that car.
  29. 56KUSTOM
    56KUSTOM
  30. Charlie Jones
    Charlie Jones
    from Apopka FL.
    I vote for the 49. Build it with a 394 Olds backed up by a topshift Cad / LaSalle ******.
