Technical Olds intake
Discussion in 'Traditional Hot Rods' started by ruben solis, Jan 15, 2023.
  1. ruben solis
    ruben solis
    Will a 303 olds intake fit a 324 and out there have an intake
  2. 38Chevy454
    38Chevy454
    Yes, Olds have three deck heights which affects the manifold width. 303/324, early 371, and late 371/394. So intake interchangeable between 303 and 324.
    saltracer219 likes this.
  3. saltracer219
    saltracer219
    Yes, the deck height is the same but be careful, the 303's had small ports so when you try to use a 303 manifold on a 324 they will not seal at the top. I just welded up and machined the runners on an early Edmunds 2 x 2 so I could raise the ports to fit a 324 with #10 heads.
