Olds J2 jet size? Anyone know?
Discussion in 'The Hokey Ass Message Board' started by D.SCOTT, May 2, 2013.
  1. D.SCOTT
    D.SCOTT
    Anyone know what size jets are used in J2 tri-power carbs? Or what size I should use in them if I have a hot cam in my 371? Any help much appreciated! And yes, I googled it, searched here, and checked my Olds manuals. Thanks, Daniel
  2. Martin_F
    Martin_F
    Wouldn't that depend on your location, al***ude, also?
  3. GOATROPER02
    GOATROPER02
    from OHIO
    With TODAYS GASOLINE 62"s in the middle and 58's in the ends.......Its not 1957 anymore
  4. 24riverview
    24riverview
  5. D.SCOTT
    D.SCOTT
    Thanks guys! And Tony, thanks again for the advice!
  6. hoop98
    hoop98
    from Texas
    You need a Jet that flows about 1.0398 times the original jet for E-10
    So an approximate scale would be about 2 jet sizes.
    A/F and F/A (Fuel Air Ratio)
    E 10 14.08 --.0710
    No E 14.64 -- .0683
    Correction Factor 1.0397 for E -10
    Adding Temp/Al***ude.
    Temp/Alt Factor * Fuel Factor = Correction Factor
