Technical Olds motor ID help
Discussion in 'Traditional Hot Rods' started by Louie S., Oct 20, 2013.
  1. Louie S.
    Louie S.
    I picked up an olds motor today, and the internet is all over the place with this stuff. I hope someone can help me.
    Block 574865-4
    Heads 573305 have an 18 on center exhaust port
    I know someone here knows, Thanks in advance, Louie
  2. F&J
    F&J
    Is it 2 center bolt valve covers, or perimeter bolts around the gasket?
    I think 18 is newer than 57/58 first generation 371.
  3. Louie S.
    Louie S.
    It has 5 bolts on the valve cover, so I know it is a 371 or 394.
  4. F&J
    F&J
    There are two different 371's
    The 57-58 looks like a 324 type motor, 2 bolt covers, and with similar exhaust ports as the 324.
    The later 59-60 371 has perimeter bolts and has different shaped exhaust ports. 394 would also look like that. I am not up on those.
    I am sure you will get better info soon. There should be a stamped engine serial number on the extended deck surface of the block, but I am not sure which side. Look along the head gasket edges near the exhaust manifolds. It will be a flat machined area sort of like a Chevy pad, but Olds were on the sides. Should be a letter code prefix, then the number.
  5. Which heads are better, perimeter bolts or center bolts? Is there any difference, and are they interchangeable?
  6. F&J
    F&J
  7. GOATROPER02
    GOATROPER02
    from OHIO
    18 heads are 1959-60
  8. Louie S.
    Louie S.
    Are these heads any good for power?
  9. GOATROPER02
    GOATROPER02
    from OHIO
    Louis^^^^^little more crack prone than other years...but they work fine.
    later 64 heads are a little better......depends on your build and expectations.....the early olds engines make a lot of torque so most people are very happy with them.
  10. Tano
    Tano
    from Japan
    Cool..
  11. Not interchangable as far as I know and the perimeter bolt heads were on higher output engines like 371s and 394s.
  12. Does anyone make fake Olds Rocket valve covers for them?:D
  13. plymouth1952
    plymouth1952
    where is the motor mounts front or sides ? 1962 and older have front mounts
  14. GOATROPER02
    GOATROPER02
    from OHIO
    Different bolt spacing ..... But same principle as the 62
  15. I wish someone did. I had someone look at my 394 ( still in pieces) a while back and say is that a 454 or a 396? They made their guess based in the rocker covers and not on the block.
    I told them it was a 427 GM Mystery Motor one of 50. :rolleyes: he never figured it out.
  16. HJmaniac
    HJmaniac
    Everything you ever wanted to know about Oldses RocketV8
    http://442.com/oldsfaq/oldsfaq.htm
    http://442.com/
    <CENTER>Oldsmobile</CENTER>
    <CENTER>Frequently Asked Questions (FAQ)</CENTER>
    <CENTER><TABLE><TBODY><TR><TD vAlign=top width=250 align=center>[​IMG]<TD vAlign=middle align=center>[SIZE=-1]V 5.X LAST UPDATED 10/10/2000
    [/SIZE]
    <TD vAlign=top width=225 align=center>[​IMG]</TD></TR></TBODY></TABLE></CENTER>
  17. Ha ha Louie's uncle showed up while we were in the driveway, motor still in the back of the truck and said the same thing.
