Customs Olds Motors
Discussion in 'The Hokey Ass Message Board' started by Speedrail1964, Oct 19, 2024.
  1. Speedrail1964
    Speedrail1964
    Not knowing alot about Olds motors. I have some 303 stuff (valve covers/manifold) and would like to know what other size motors I can use them on,,,if any. Your responses would be greatly appreciated
  2. tubman
    tubman
    I believe that the valve covers will interchange with the 324's ('49-'56); I believe the later covers have perimeter hold down bolts rather than central mounting studs. As to intake manifolds, I believe they will bolt on, but Oldsmobile changed their intake port size several times in the 303/324 era and you could end up with serious port mismatches.
    skooch likes this.
  3. skooch
    skooch
    warbird1, 302GMC, oldsmobum and 2 others like this.
  4. J. A. Miller
    J. A. Miller
    from Central NY
  5. HEATHEN
    HEATHEN
    from SIDNEY, NY
    The heads and intake manifold are '49-'53. They can be used on '54-'56 engines if used in unison, although that would be a step down from the later heads, which have larger ports.
