olds rear end
Discussion in 'The Hokey Ass Message Board' started by jdownunder, Aug 28, 2009.
  1. jdownunder
    jdownunder
    hi there ,ive heard olds rear ends are strong.i have 1936 rear end and was
    wondering wether this would handle sbc 350, i didnt really think so but
    a few people have commented.just thought id run it by the hamb.
    thanks justin.
  2. flying clutchman
    flying clutchman
    The olds rear ends that every one buys up for their strength are the 57-64 olds/pont rear ends. they have a huge 9.3 ring gear. can rake some harsh abuse. as far as your 1936, i dont have a clue!
    clutchman
  3. dreracecar
    dreracecar
    from so-cal
    It all depends what you plan to do with it. Just idleing around should be fine .but if you plan to hammer it, not so good. Heres a trick if people can see the housing from the back. Take a 49 to 51 Olds housing and remove the rear cover and weld it to a Chrysler 8 3/4 housing along with the axle bearing ends. They are close in size and shape and parts availability is greater and one can easily put 800hp to it
  4. the olds u-joint caps are super weak on the early rear ends. sheared a bunch of them, but then again your only running a small block chevy. :)
  5. jdownunder
    jdownunder
    thanks for the input!
  6. OL 55
    OL 55
    This might help.........
    <TABLE cl***=tborder id=threadslist cellSpacing=1 cellPadding=6 width="100%" align=center border=0><TBODY><TR><TD cl***=alt2></TD><TD cl***=alt1 id=td_thread***le_129676 ***le="I figured since we have so many Pontiac/Olds rearend threads out there we could try to narrow some of the good info down to just one thread...so I've got some questions to ask and I'd love to get them answered, along with posting other helpful hints from some of the other threads... &#10; &#10;'57-'58...">[​IMG] [​IMG] Pontiac/Olds Rearend TECH...post it here...
    </TD></TR></TBODY></TABLE>
  7. wardo01
    wardo01
    from reno
    Hey I just got a micky thompson magnesium center section with 4.10 and from what I have read it must be a 56 because it has a 10 spline axles and it has a 10 spline pinon shaft it came with a coupler and I need a yolk does any body know were I could find one or do I need to buy a new gear set with a different spline count or is this diff worth any thing to any body should I s**** this and start with a different diff I really like this one but I'm having a hard time finding parts???
  8. cb1
    cb1
    from Wisconsin
    That there is one hell of a sentence.
  9. wardo01
    wardo01
    from reno
    Well thanks for that but I really wanted some help on where to find parts.I really need a yoke for this pinon shaft. So if there is anybody that knows helpful information I'd like to hear from you
  10. H.G. Wells
    H.G. Wells
    Try Mark Williams Enterprises
