Olds Rearend ID
Discussion in 'The Hokey Ass Message Board' started by 00-DIRT, May 17, 2012.
  1. 00-DIRT
    00-DIRT
    I am trying to find out more info about a rearend. It is supposed to be 60's olds. I have looked for the stanmped numbers on the tubes, but believe they may have been welded over as this was ran in a drag car, but i did find casting numbers on the carrier. here is what i have found A262 and right below that is cast 35200 right before the three is what appears to be a lower case o but i dont know. It is a 10 bolt carrier. i can get pictures and post if needed.
    Thanks
    Dirt
  2. F&J
    F&J
    If you know how to use the search feature here, there is a big thread on those rears with ID's and tech stuff. Look for Olds Pontiac Thread. If you can't find it, I will try.
  3. swe64
    swe64
    59-62 pontiac have same casting nr ending with 200
    ken
    sweden
