Projects *oldsboy*_T-sedan build
Discussion in 'Traditional Hot Rods' started by oldsboy, Jan 11, 2011.
  1. Wow, just wow! Really nice work.
  2. Tim
    Tim
    from KCMO
    Looking good! If you head to the drags you should give me a hollar and swing by the new place :)
    Posted using My **** Tracey watch and the full custom HAMB app
  3. oldsboy
    oldsboy
    Thanks guys.
    Tim. I'm not sure if I'm going to be able to make it down this year, wedding and such. However now you are down there be prepared...just be prepared.
    brEad likes this.
  4. Tim
    Tim
    from KCMO
    Haha, I've got a decent sized garage a driveway that will hold at least 6 and enough bedrooms for the partridge family. I suppose I should mow the lawn and rip weeds out of the driveway but then I'll feel prepared.
  5. Tim
    Tim
    from KCMO
    Edit: I need both an American and Huskers flag to hang then I'll feel ready
  6. oldsboy
    oldsboy
    I've been meaning to load these up as well... I have seats now and they couldn't have turned out any better, so I'm extremely thankful. My good friend Joe (lowtruck) did an outstanding job on all of the upholstery work.
    They are '32 sedan seats which I wanted for the accessibility and overall design rather than a solid bench. So we came up with a pattern and upholstery which seemed to be the right fit for the era the car is going. Again I'm pretty excited to get in and try em out....
    Construction/ Modification for new seat back....
    brEad likes this.
  7. chaddilac
    chaddilac
    Powdercoating will not fill in pits! At least it didn't on my model A wheels!
  8. oldsboy
    oldsboy
    Yeah, I had the same experience with my wires unfortunately. Maybe if the pits aren't too severe I could see some filling. I think its a good approach though if you were fortunate enough to have a nice clean frame.
    I think I'm leaning towards the Hirsch "super" ch***is black - brush on approach....
  9. chaddilac
    chaddilac
  10. oldsboy
    oldsboy
    Semi.
    I'm planning on all suspension, frame, engine and rear to be painted with semi gloss black. Then leave the transmission the color it is (original ford red) and do the body somewhere in the range of an early 40's maroon (eventually).
  11. olskoolrodder
    olskoolrodder
    man... great work! looking awesome...
  12. chaddilac
    chaddilac
    Sweet!!! That'll look awesome! I did my frame in gloss black and it looks so freakin' good!!!
  13. Tim
    Tim
    from KCMO
    Cool! Seats kinda remind me of an old bomber jacket :)
  14. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    You can have them go really thick and as long as we're not talking about ladybug size pits it should fill a lot of them pretty good. You can also use things like All Metal and such to fill the larger ones.
  15. flatheadpete
    flatheadpete
    from Burton, MI
    The seats are super cool.
  16. oldsboy
    oldsboy
    Now that I'm thinking about it...would you recommend gloss over semi for the frame? I would think it might hold up better in the long run.
  17. oldsboy
    oldsboy
    Thanks Pete. They did turn out really well and to top it off they are pretty comfortable, seeing as there is only about 2" of padding to them.
  18. chaddilac
    chaddilac
    Gloss will be easier to keep clean because its smoother! I just think it looks more finished too. Your T is gonna look awesome, I personally think the gloss frame will complete the look better.
    Atwater Mike likes this.
  19. oldsboy
    oldsboy
    Agreed. Talked it over this weekend and I think ill hold out for spraying it and the suspension as opposed to brushing it on as well.
    Looks like ill be investing in some high build primer and filler afterall.
  20. Tantank49
    Tantank49
    from 61401
    High build primer? Try some Slick Sand made by Evercoat. #709 for grey. The stuff is amazing. Like spray on bondo.
  21. oldsboy
    oldsboy
    Well...Jeffrey I think I'm going to go the powder coat route. I've worked the metal up to a good point where I can finish the rest of it pretty well with all-metal and have it all powder coated. Seems to be a good idea, as it'll be less hastle and more permanent and hopefully last a bit longer.
    I did get around to working on the clutch/pedal ***embly this weekend. I ended up like everyone else having to modify that x-member but I think it should hold up pretty well. On top of that I had to flip the pedals which should allow for enough clearance now without losing any mechanical advantage from their initial design.
    Lastly I received my carbs form UncleMax here on the hamb and boy did they turn out well. Can't explain how well these came out. Thanks again Max.
  22. Tim
    Tim
    from KCMO
    Oh yeah man that's the good stuff right there!
  23. daddio211
    daddio211
  24. oldsboy
    oldsboy
    Well... in 8 days I'll be getting married so before that and for a little while I wanted to post where the motor progress is and share a little eye candy as well.
    All of the parts are sitting in my garage awaiting my return from the Honey Moon for ***embly. In the mean time I had to do a mock up since it will be a little while before I can get back around to it.
    Sooner than later this little guy will hopefully be idling with any luck.
    Wish me luck.
  25. daddio211
    daddio211
  26. Tim
    Tim
    from KCMO
    Love that intake man, J's got one on his coupe as well and it always catches my eye.
    Sorry I can't be there for the huge day but I'll be thinking about you two. Have an amazing day man.
    Posted using My **** Tracy watch and the full custom HAMB app
  27. gordspeed
    gordspeed
    from Oregon
    This is turning into one bad T! Nice job! That motor is getting ***y too!! :)
  28. nailheadroadster
    nailheadroadster
    VERY impressive! Great eye for detail and amazing execution!
  29. oldsboy
    oldsboy
    Thanks Timm! We'll have to get together post wedding.
  30. oldsboy
    oldsboy
    Thanks guys!
