Technical Oldsmobile 3 speed floor shifter advice needed
Discussion in 'The Hokey Ass Message Board' started by novaskilling, Oct 15, 2025.
  1. novaskilling
    novaskilling
    IMG_7527.png IMG_7527.png IMG_7528.png IMG_7527.png I recently bought a 51 or 52 Oldsmobile 3 speed transmission to put behind my 331 Cadillac. I know nothing about these transmissions and was hoping someone could help me find a floor shifter or school me on what floor shifter to search for. Attached is a photo of the trans, it came with the clutch the pressure plate the bellhousing and all smalls.
    chryslerfan55 and 51 mercules like this.
  2. BJR
    BJR
    That is a selector transmission. Takes a special floor shifter. Hard to find.
    saltracer219 likes this.
  3. novaskilling
    novaskilling
    Thanks for helping identify it, appreciate that.
    chryslerfan55 and BJR like this.
  4. F&J
    F&J
    https://www.jalopyjournal.com/forum/threads/hd-bop-selector-trans-floor-shifter.1300600/
    Follow the link in that thread highlighted in red from Paul to see more shifter pics.
    Also, the Olds bell is a slightly different bolt pattern compared to early Cadillac pattern. You'll need to drill and tap for at least two more holes at around 3 and 9 o'clock. I believe only the top two and bottom two holes will line up with the early Cadillac engine pattern.
    RMR&C, chryslerfan55 and Tim like this.
  5. jet996
    jet996
    from WY
    I think I have one of those shifters for a selector transmission. I'll look.
    RMR&C likes this.
  6. novaskilling
    novaskilling
    Thank you so much!
  7. vtwhead
    vtwhead
  8. tubman
    tubman
    I had the same transmission in a '50 Buick. I made my own floor shifter from a long 1/2" rod, two heim joints, and a short piece of angle iron. It shifted backwards, but that was an advantage because 3rd ended up out of the way towards the dash.
    The angle iron bolted to the top of the transmission and had a hole drilled on it to accept the top heim. The rod p***ed through this and had a smaller heim welded on the end that accepted the bolt on the shift lever. It worked well until I sold the car. I was always going to spring load it towards the 2nd-3rd side and weld on a tapered shift lever with a fancy knob, but it worked so well the way it was that I never got around to it.
    bschwoeble and 51 mercules like this.
  9. bschwoeble
    bschwoeble
    I and a buddy made ours in high school auto shop back around 1962. We got the idea from Car Craft (I think) when they did an article on a 57 Olds floor shift conversion.
