Oldsmobile 394 help !
Discussion in 'The Hokey Ass Message Board' started by 0rg0, Oct 21, 2010.
  1. 0rg0
    0rg0
    So I got this 394 with the intention of using it in a Model T. I love the engine, but I don't think the slim jim is the way to go.
    Yes I have read the extensive info on here about these things.
    I just can't afford to go and buy the adapters and flywheel that are available for this engine. I need some other transmission options. Something that I can adapt myself. These engines have a long history, somebody here must have a few ideas.
  2. HEATHEN
    HEATHEN
    from SIDNEY, NY
    If you don't want to spend the $$$ for adapter kits, the only other choice is the dual coupling hydramatic. Dual range hydros ('52-'56) can be bolted to your engine, but you'll need a flywheel/torus cover with the correct balance for a 394.
  3. selohssa
    selohssa
    Sounds like a cool engine for the T. It would be a shame not to use it.
  4. 56sedandelivery
    56sedandelivery
    Dual range Hydro, or possibly a stick shift trans; nothing else seems right. Butch/56sedandelivery.
  5. BobF
    BobF
    from Poway, CA
    Well, as you're finding out early Olds and cheap don't work well in the same sentence. The 4speed hydros will work, but again rebuilding and parts are $$$ and as mentioned you need the proper flywheel/torus cover/lower bell/starter combo.
    I put a 50 (303) in my Model A back in the late 50's (58or59) and I used a Ford truck clutch a thin 3/16" half moon adapter plate($19) and a 37 Ford floor shift ******($15) coupled to the stock torque tube. This was the cheapest route at the time and may still be today, however the definition of "cheap" is significantly higher. Back in the day the most expensive part was the std flywheel which was almost impossible to find in a yard because most all the cars came with the automatics. The std flywheels were grabbed up immediately out of the yards. The alternative was buy it new from a dealer via body shop or mechanic discount, still almost $40 in those days. If you can come up with a std flywheel there are reasonable $$ adapters out there for early Ford (late 30'sfloor) or later side shifters. Could even use a later 60 -70s 3 or 4 speed.
    The conversion to later automatics is more $$$ because of the bell cast on the back of the early Olds/Cad blocks making things more complicated which means more $$$ to un-complicate it.
  6. xlr8
    xlr8
    from Idaho
    If the slim jim is in running condition I'd use it until it fails. They aren't as bad as people like to make them out to be.
  7. aerorocket
    aerorocket
    from N.E. P.A.
    This is true. I was 16 when my dad got his 63 starfire and I beat the hell out of it and it was still going at 80k when he traded it. My cousin had a 62 88 rag top and his brother hammered it also and it was still going till he totalled it although I think it only had 40k on it.
  8. 0rg0
    0rg0
    Some good ideas so far.
    I like BobF's thoughts. Too bad we still don't have 1959 prices, or 1959 junk yards. These are the kind of solutions I'm looking for. Bob, only 33 posts in the last 6 years ? And I get one ? I'm honored.
    xlr8 you bring up an interesting point. My cheapest option is to use the slim jim. I have 2 of them, don't know how well they work though. They must have been at least somewhat tough to be behind these beastly engines from the factory.
  9. 0rg0
    0rg0
    Maybe we could get some tales of Slim Jim success stories.
  10. plymouth1952
    plymouth1952
    had one behind a 2x4 394 and worked good.
  11. fatkoop
    fatkoop
    Had a Slim Jim behind the 365 Caddy in my '29 tudor. Drove the **** out of it for years. Wouldn't be my first choice today, but if that's what you have available, and it is in good condition, I'd go for it in a heartbeat.
  12. 0rg0
    0rg0
    Anybody else?
  13. 0rg0
    0rg0
    So I parted out a '51 Olds last weekend, and it had the 303 with a 3 speed in it. I've been reading on here, and it looks like it's a Caddy ****** ? Can anybody confirm this ? And it might work with my 394 (with some work) Anybody done this before ?
  14. HEATHEN
    HEATHEN
    from SIDNEY, NY
    If it looks like a sideshift Cadillac/LaSalle transmission, except with a much shorter tailstock, it's a '50 Olds gearbox. In '51, they went to a rather strange "selector" transmission with a six bolt top cover, one regular size shift arm, and one tiny shift arm. If it's the '50 transmission, don't hesitate to use it and, yes, the bell housing will bolt up to the 394.
  15. Gman0046
    Gman0046
    You sure don't want the transmission with the rail selector and the gear selector. Chances of find an old Ansen shifter is slim or none. The transmission like the 50 is what you want or a Cad/LaSalle if you could find one.
  16. Sir Woosh
    Sir Woosh
    Had a 55 Olds a lifetime ago that I rescued right out from under the claw at the local recycle center for $125. Someone had already stuffed a 394 in it, but it was blown and broke up bad inside. Lucked into 1961 low mile sedan that took a slow rollover for $100. Dropped the drivers side air box from the firewall and put the 61 brake system in. Low buck car so I did a flip nose on it and ran the hell out of it. That stock 394 and slim jim went through a lot without fail. Sold it to a guy who had NO mercy on it. Crazy how that car ran for what it was and what it went through.
  17. 0rg0
    0rg0
    So I extracted the transmission from the 303, and it's the 6 bolt top cover type. Getting mixed signals on this one. Some say run away from it screaming, and others say it rules.
    I guess everybody has an opinion. I think I'm gonna use it. I don't really have a better option. so...
    What do I need to do to make this work ? So far I figure I need to get the 303 flywheel balanced, and the 394 crank drilled for a pilot bearing. Anything else ?
  18. They just weren't a dragster ******. in a light vehicle if its operable you shouldn't have any problem with the slim jim. I'd run it if I had it.
  19. HEATHEN
    HEATHEN
    from SIDNEY, NY
    It's not that the transmission wasn't rugged, or had bad gear ratios; it's mainly an issue of shifting the stupid thing. I've got a n.o.s. floor shift conversion for one that's not for sale, but I can take some pictures of it if you want to see what you're up against.
  20. 0rg0
    0rg0
    Pictures are helpful. Much appreciated.
    I also took the dash, and the steering column from the car, ('51 Olds dash in a T-coupe seemed like a good idea to me), so I could set it up with 3 on the tree if I had to.
  21. cloned clown
    cloned clown
    0rg0...you read my mind. I had the same question as I am also building a T coupe with a 394. I look forward to reading some of the responses this thread gets!! :D
  22. Paul
    Paul
    Editor
    there's a thread with pictures of some shifters for the selector transmissions..
    bolt pattern on the 303 flywheel will be different than the 394
    as well as the ballance as already stated
    edit; found the thread:
    Rocket Olds Swap Meet Holy Grail
  23. 0rg0
    0rg0
    Thanks Paul. I read that thread before I had the Transmission and thought I wish I had one of those. I might try to build a shifter like that. Probably easier than finding one.
    Is getting that flywheel to bolt up as simple as having it drilled to match the crank ?
  24. 0rg0
    0rg0
    394 in a T coupe should be a good time hu ?
  25. EMPEROR CHUCKYBOY
    EMPEROR CHUCKYBOY
    yeah i agree keep the 394 running with the slim .... just save up and get a stick behind it some day ....I have no mercy on my MC-1 behind my 56 324......
  26. junkyardjeff
    junkyardjeff
    A 59 or 60 jetaway is a better trans then the slim jim and should bolt up.
  27. 0rg0
    0rg0
    I got the stick, and it only cost me $25. I just gotta figure out how to make it all work together.
  28. lawman
    lawman
    Ther is some great info here Guys. Thanks for posting. Tom (Tired Old Man)
  29. lothianwilly71
    lothianwilly71
