Technical Oldsmobile generator bracket
Discussion in 'The Hokey Ass Message Board' started by Paul, Aug 9, 2025.
  1. Paul
    Paul
    Editor
    I made a few of these in the past,
    'copied them from an original bracket that came with an old Belond header set, used on a long gone project.
    In the past I cut the plate with whatever tool I had at the time, torch, grinder, etc.
    this time I drew it up in CAD and cut it out on the plasma table.
    Here is a series of photos to show the process and final product.
    PXL_20250809_161128377.jpg PXL_20250809_161121940.jpg PXL_20250809_161412343.jpg PXL_20250809_161142630.jpg PXL_20250809_161523081.jpg PXL_20250809_161645833.jpg PXL_20250809_161828045.jpg PXL_20250809_162043473.jpg PXL_20250809_162120174.jpg
    Bcap55, Chief 64, alanp561 and 22 others like this.
  2. wheeltramp brian
    wheeltramp brian
  3. Tim
    Tim
    from KCMO
    Excellent
    porkshop, Paul and Sharpone like this.
  4. Marty Strode
    Marty Strode
    Paul, you are making good use of that table, great parts. Hope to see you at Toutle !
  5. skooch
    skooch
    This is how and where I mounted my ac condenser. My cobbled together bracket is no where near as pretty as this and it didn’t occur to me to use studs instead of bolts.
  6. Paul
    Paul
    Editor
    thanks Marty, yes looking forward to it!
    porkshop and Sharpone like this.
  7. Sharpone
    Sharpone
    Nice, did you make the header flanges also?
    Dan
    duecesteve and porkshop like this.
  8. Mr48chev
    That's a nice unit there. A whole lot less hours than doing it by hand with a cut wheel, grinder and drill too.
    duecesteve, porkshop and Sharpone like this.
  9. Paul
    Paul
    Editor
    total time spent on getting the first one acceptable is probably comparable,
    but then it becomes very quick to repeat.
    this took two trial runs, one with thinner 1/8" plate to check fit then another minor adjustment in 1/4" plate to get the final cut right, one trip to the wire wheel on the bench grinder and done.
    much nicer to work with than all that grinding, drilling and sanding mess.
  10. Paul
    Paul
    Editor
    thanks, no, I bought these a few years ago, obviously done on a similar machine.
    not sure if my little 45 amp cutter could handle the 3/8" material these are made of. 'may have to give it a try.
  11. Sharpone
    Sharpone
    Looks like a lot of fun. Great for brackets and what not.
    I made a header flange for my OT Sprite using a drill press, jig saw, angle grinder and die grinder with carbide burrs, it took a while.
    Dan
    duecesteve, porkshop and Paul like this.
  12. 57JoeFoMoPar
    57JoeFoMoPar
    Love it. I had to make something similar years ago to mount an alternator on a 394 but I made it out of a couple pieces. Yours is much better and cleaner. Great job
  13. Good photos. Good post.
    You are a true ***et to the HAMB community. :cool:
