Technical Oldsmobile Rocket 303 Rocker Arms
Discussion in 'The Hokey Ass Message Board' started by junk_yard_jack, Mar 26, 2017.
  1. junk_yard_jack
    junk_yard_jack
    Hi everyone! I am rebuilding a 1949 Olds 303 for use in my hot rod. The engine I am rebuilding apparently had 1.8 rockers on one side, and 1.5 rockers on the other!! Obviously I don't want to do that.
    Does anyone have either a 1.5 setup or a 1.8 setup that they would sell, or trade? Perfect for me would be to trade the 1.8 for a 1.5 even steven, but I am open to any suggestions.
    thanks,
    Jack
  2. VTjunk
    VTjunk
    Put the 1.8s on the exhaust side?
  3. VTjunk
    VTjunk
  4. junk_yard_jack
    junk_yard_jack
  5. VTjunk
    VTjunk
    So you could run either the stock 1.5 ratio or use the 1.8 for a slight bump in performance. Probably not a good idea to split them between intake and exhaust, that's too much of a difference in ratios. Check the piston to valve clearance anyway, especially if you're using upgraded pistons for more compression.
  6. VTjunk
    VTjunk
    I'll look to see what I have.
  7. ROADSTER1927
    ROADSTER1927
    I have the stock rockers you need and will trade for the 1.8 ones you have. Gary
