Oldsmobile Rocket Motors
Discussion in 'The Hokey Ass Message Board' started by Nick32vic, Sep 6, 2003.
  1. AssGasket
    AssGasket
    Ask DonWow.....
  2. mykwillis
    mykwillis
    glad i could help. :D
  3. r0cket88
    r0cket88
    Camcraft can grind you a cam for the 1956 324s, 371 and 394s. I don't think they have anything for the 303s or the early 324s. Does anyone have a Olds standard trans they'd part with? Thanks...
  4. r0cket88
    r0cket88
    Camcraft can grind you a cam for the 1956 324s, 371s, and the 394s. I don't believe they offer anything for the 303s, or the early 324s...
  5. RoyalCrown32
    RoyalCrown32
    I bought a cam for my 1953 Rocket Olds from Schneider Racing Cams. Custom grind to my specs. Great guys to deal with and good advice too.
  6. RoyalCrown32
    RoyalCrown32
    Camcraft can regrind a stock cam for the 303's.
  7. Pete
    Pete
    Yes, the lifters are slightly different. The pushrod pocket is higher on the chevy lifter which pushes the valves open....no compression...just went through this on my motor. I bought a 324 that was rebuilt, installed in the original car and would not run! The guy got fed up because he couldnt figure it out. I bought the whole car, stole the motor, installed it in my coupe and found it would not run. after some investigating and talking with the old timers I found that the generic upgrade for lifters were the SBC units. I had to get shorter push rods and fiddle diddle with the right combo until I got it right.
    Pete-
  8. I have a 53 Super 88 and cannot find a good 303 rocket anywhere. i just want to put something in it for know to get her going and then when im finished university i might be able to afford one.
    can anybody help me out with what a good alterante choice is for dropping in. something somewhat affordable and easy to find
    please..... i got this thing for my 16th B-day and I its been six long years...
  9. F&J
    F&J
    You would spend tons of time AND money putting a different type of motor in....IF you actually have the determination to finish such an involved swap, once it's all torn apart and looking like a "too big of a project for me".
    Just a short list: Motor mount & trans mount fab, driveshaft mod, exhaust fab, radiator mod?, trans linkage mods, wiring etc. You will wish you didn't try it unless you have experience in swaps.....plus the car will be all apart and you will be more behind in your dream.
    I'd save a few bucks for a 303-324. Yes they are still out there, and you can find a hauler to deliver it. That's what I did.
  10. 31ACoupe
    31ACoupe
    You need to beat the bushes. I just bought a nice 303 motor and ****** for a reasonable price (I think). Didn't even know the guy had it, it was in an old 51 Hudson he is restoring and is putting back in the Hornet motor. My rocket 303 had less than 100 miles on a complete rebuild when he parked it and his dad was the original owner. I am real happy with this find and they are out there, you just have to know people and ask a lot of questions.
  11. pete324rocket
    pete324rocket
    I find this a bit hard to believe because from examining the lifters,you'd have a hard time ever telling the difference.Plus even if there was a little extra height...wouldn't the lifter take up the difference like it is supposed to and find its 'sweet spot" to function properly?
  12. racerjohnson
    racerjohnson
    from Fargo, ND
    btt. Looking for closure on this.
  13. Bobert
    Bobert
    Not exactly sure what you are looking for, but the desired lifter preload is usually between .020" and .060"(some say .050"). A pushrod that works with Chevy lifters in a 303" engine is about .125" shorter than the stock Olds pushrod. So it would seem then that the stock Olds pushrod would not work with the taller Chevy lifter in the proper range. Not enough range left in the lifter to compensate for the long pushrod.
  14. petritl
    petritl
    from Marion, TX
    This next week I may have a running 1965 Oldsmobile Starfire engine w/ TH400 transmission (switch pitch?) for sale.
    The engine is a 425ci factory 370 HP ultra high compression engine.
    I am selling my Starfire convertible and it doesn't appear as the buyer wants this engine.
    If the car sells I will post the engine and trans in the forsale section
    Tad
