? on rear axel
Discussion in 'The Hokey Ass Message Board' started by d100hemi, Aug 16, 2011.
  1. d100hemi
    d100hemi
    from washington
    i have a 9" ford rear out of a 78 ford f150 would i have to shorten it to us it on a t-bucket frame?
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    Not unless it is important to you that the center section is centered in the ch***is.
  3. fiftyv8
    fiftyv8
    from CO & WA
    I'd do something to it just to pretty it up a little especially in a T bucket like Pasdena says.
  4. Used Up Junk
    Used Up Junk
    from Merced, CA
    I think that rear axle is going to end up being WAY to wide for a T-style frame. I usually try to find something in the 56" wide range what is the hub to hub measurement on your axle?
  5. 117harv
    117harv
    An 8" rear would be a good choice, lighter, smaller, and narrow ones are common.
  6. hotcargo
    hotcargo
    or do what I did years ago .......
    customer gave me a wide Galaxy 9" to use , I set it up in the T bucket ch***is , but I widened the back of the T bucket body 5 1/2 " and widened the bed to match .
    ...................... and it didnt look out of place either
    cheers
    Steve in Oz
  7. HOT40ROD
    HOT40ROD
    from Easton, Pa
    The rear you got is 65 1/2 inches from wheel flange to wheel flange and has the 5 on 5 1/2 bolt pattern. The best part about that rear is that it being that wide it will be easy to center the center section. It also should be a 31 spline large bearing axle rear and there should be no issues cutting the axles. and the hubs can be re drilled to the 4 1/2 or 4 3/4 bolt pattern.
