once again please. Removing paint from models?
Discussion in 'The Hokey Ass Message Board' started by Revhead, Aug 9, 2004.
  1. Revhead
    Revhead
    from Dallas, TX
    How do you do it? I just attempted to spray a model I owe someone and the brand new can of paint turned out to be crap.
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    Soak it in brake fluid. no kidding
  3. Anderson
    Anderson
    I know brake fluid works but I haven't tried it.
    I usually soak them in Castrol Super Clean (known as the "purple pond"), it takes a day or so.
    And I've also heard VERY good things recently about 91% alcohol you can get from a drugstore or something.
  4. crewcutkid
    crewcutkid
    from m
    Bleach works fine. Just let 'er soak, and she'll be right as rain.
    -Crew
  5. hotrodsnguns
    hotrodsnguns
    from Fresno, CA
    I have used my daughters nail polish remover, seemed to work the one time i did it.
  6. I use EasyOff oven cleaner. It takes a few coats to get it done, but it doesn't hurt the plastic.
    Rev. Jake Toocool
  7. Mojo_AL
    Mojo_AL
    Easy Off oven cleaner works well also. Depending on the type and brand of paint, I had variable results but it might be worth a try. Just spray it and put it in a sealed container for a day.
  8. Anderson
    Anderson
    I've found CSC works better than Easy off. Plus, my lungs don't feel like they're being dissolved with acid in case I breathe in some CSC as they do with oven cleaner...
  9. Mojo
    Mojo
    I prefer a swim in Lake CSC myself. I've tried all the above, my second choice it Brake Fluid. Easy Off is great for very thick, newer model paints (new seems harder to strip than old paint jobs).. and I couldn't agree more about breathing it in... one good huff, and you'll want to DIE.
    As for CSC, wear some gloves! It didn't make my hands burn at all, so I thought I was fine. Well, when I tried to wash up, it wouldn't come off! It took off the top layer of my skin though, and I thought my fingernails were never going to harden back up. Good shit, it'll strip enamels and lacquers easily...
  10. Revhead
    Revhead
    from Dallas, TX
    thanks for all the replies. I'll try some of the less hazardous suggestions first since it was just a light coat before I realized the paint was bad.
  11. Westley's and Castrol won't touch the new acrylic paints (water based) Brake fluid is great, but some really old plastics get brittle from it. I don't know why, but thats my experiance. [​IMG]
  12. old beet
    old beet
    I usually wipe um down with Crisco, towel um off, and tell them to take a shower. Call a cab, the money in on the table. I'm goin to sleep now. Bye Bye!.........OLDBEET
  13. du$ty
    du$ty
    just leave that shit to k&r you hack! [​IMG]
  14. NealinCA
    NealinCA
    Has anyone tried these methods on other types of plastics, like a steering wheel?
    I have a 39 Ford steering wheel and horn button that are very nice, except someone had painted them. I would like to get back to the original Ford color. Any thoughts? The horn button has a fine V-8 that I don't want to lose.
    Neal
  15. Revhead
    Revhead
    from Dallas, TX
    Alright.... If you say so Dusty. Eric, you wanna clean this paint off my model? [​IMG]
    by the way it was testors spray paint. castrol gonna be able to handle that?
  16. du$ty
    du$ty
    you guys need to stop messing around and huff that shit.
    or go get some girlfriends. [​IMG] or both...get some girls and huff some model glue and stripper...now thats kustom kulture.
  17. Anderson
    Anderson
    Well the stuff removes paint, but is gentle enough to not harm the plastic underneath...I dont see why It wouldn't strip paint from enything else.
    Tell ya what....drive to Denton, I'll strip the paint for FREE, then you come back and get the model.
    I heard that Flexicoker can remove the chrome from a trailer hitch ball, maybe he could help??
  18. whodaky
    whodaky
    from Aust
    I use caustic soda mixed in water Geoff aka Whodaky
  19. HotRod60F100
    HotRod60F100
    Be careful using nail polish remover as it will easily turn your plastic into a rubbery goo,i ruined a cool old Aurora AFX slot car body trying to remove the old paint [​IMG]
  20. Danny909
    Danny909
    use westleys bleach white for tires. not only will it strip paint it also strips chrome. just my two pesos [​IMG]
