Projects One for Daddy-0, Model A Coupe Build
Discussion in 'The Hokey Ass Message Board' started by scoggman, Feb 16, 2011.
  1. oldman2
    oldman2
    Jon, I'm like you can't beat the free stuff. After you get her running lets us know how it did temp. wise...Jim
  2. scoggman
    scoggman
    Got the carpet and mini van seat in. Going to wrap it in a mexican blanket.
  3. scoggman
    scoggman
    Well.... took a look at the vortec heads I bought and one ended up being cracked.... bummer..... then the next night I tore down my engine.... just to find out it was full of water.... rust.... and was cracked..... now we are lookin for a new motor..... maybe even a 5.3 lsx..... don't know what to do... kind of bumbed....
  4. go-twichy
    go-twichy
    is that an engine or a planter!
  5. scoggman
    scoggman
    That is funny...... true..... and sad...... :(......
  6. bjinx
    bjinx
    Been following this thread since the beginning its one of the better ones on the board. Just my 2cents, but a GM 350 long block crate motor could be the answer. I put a 260 hp one in a '40 ford pickup and it was plenty of motor for the truck. I also have a 290hp one in my O/T '70 shortwide pickup. I believe the 260hp one is under $2000.00 and the 290hp one is just over $2000.00. They are both 3 yr. 50,000 mile warrenty. Just a thought. Again great project, going to be a great car.
  7. scoggman
    scoggman
    Thanks man, I really appreciate it!!! Been lookin at the blue print 383's.... but it just isn't in the budget right now. Been having my buddies out turnin over rocks trying to find as decent junker, then save up for something better. Thanks again!
  8. n847
    n847
    Yeah man thats a bummer but I know you can find a decent sbc in running driving condition for around 500 $ that car cant have an LS motor...it just wouldn't be right!
  9. scoggman
    scoggman
    Well.... I picked up this motor for $230 yesterday. It was in a car and I got to ride in it before the guy pulled it out. It smoked when you got on it.... so now what to do.... do I rebuild it...re-ring it.... or just drive it and save up for a crate motor. Ideas and opinions welcome. Thanks! Jon
  10. Leviman
    Leviman
    Nice! Cheap is great. You can't beat LS motors for all out cheap power.
  11. Soviet
    Soviet
    LS? What?
    Check plugs, check compression, make decision from there.
  12. daddio211
    daddio211
    I agree. If it checks out good run it so you have a drivable car. Once the car is "complete" and you're enjoying it, THEN build a new engine.
    My '27 T Roadster build:  http://www.jalopyjournal.com/forum/showthread.php?t= 734383
  13. n847
    n847
    What he said!
  14. scoggman
    scoggman
    Yeah, it was burnin oil pretty bad, just wonderin if I should break it down and try to re-ring it.... or just run it.....
  15. zeuglodon
    zeuglodon
    re-ring kit from Summit is like $85 (rings, bearings, gasket set)
    you can get one of their house brand cam and lifter kits for anther $85
    tear it down, clean it, hone it, slap it back together -you'll be surprised at the improvement for less than $200
  16. scoggman
    scoggman
    Man, that is what I am thinkin. Thanks, I appreciate it!
  17. WB69
    WB69
    from Kansas
    I agree with Zeuglodon. You'll wish you did later.
  18. scoggman
    scoggman
    Well.... I couldn't stand it so I pulled the head off the side that was smoking. One of the pistons looked washed, and the others looked the same. The head had a lot of carbon on that one cylinder. What does this mean?
    The washed one, you could still see the hone marks, the others you couldn't. Does this mean the rings didn't seat, or has someone already tried to re-ring it?
    Let me know what you think.
    Thanks,
    Jon
  19. wannadrag
    wannadrag
    from WI
    Flat tops in a newer 350?Am I seeing 060 on the piston?If so you have a wore out engine.
  20. Tim
    Tim
    from KCMO
    lookin good man, your close!
  21. powrshftr
    powrshftr
    It says .030 he is fine
  22. gregaustex
    gregaustex
    from Austin
    Just read all 14 pages. What a great story and imaginative build. Good luck with getting her back together. I miss my time in Arkansas, it was a great place to grow up.
  23. woodbutcher
    woodbutcher
    :D Good job.For a first build.GREAT.
    Good luck.Have fun.Be safe.
    Leo
  24. scoggman
    scoggman
    Thanks man! I appreciate it! What part of Arkansas are you from?
  25. scoggman
    scoggman
    Thanks man!
  26. scoggman
    scoggman
    Well.... build update... It looks like the smoke issue was that the guy didn't install the two oil rings on each side of the crazy lookin oil ring. So hopefully that stops the smoke!
    But... I pulled off one of the main caps and it was shot, and the crank was real bad. I plastgsuged it, and it didn't even really squish.
    So I decided to pull the crank out of my cracked block. It looked real good, but.... I knicked a couple of the journals trying to knock out the stuck pistons.... but I dropped it off at the machine shop and they said it should polish up fine.
    If everything checks out, I'm going to order one of those Northern Auto Parts re-ring kits and get after it. Hopefully it will be a decent motor and get me through till I can get a new crate. Who knows it msy be awesome as is, we'll see.
  27. oldman2
    oldman2
    Hey Jon, thanks for the PM and good luck with the engine...Jim
  28. gregaustex
    gregaustex
    from Austin
    grew up in Fayetteville, went to university there and I've been in Austin for a long time now. Keep building! I'm subscribed and interested in following your progress.
    Good luck.
  29. scoggman
    scoggman
    Tore thr block all the way down. Going to give it a good cleaning and try to put it back together.... with all the rings this time! :) Ordered a re-ring kit from Northern Auto Parts! Good prices for a bunch of Yankees! ;)
  30. Tim
    Tim
    from KCMO
    Yeah they tend to price pretty fair and good customer service, though I've never dealt with them on the phone.
    They've been a couple minutes away for most my life prior to our move south :)
    Posted using My **** Tracy watch and the full custom HAMB app
