One mans trash. Or is it ?????
Discussion in 'The Hokey Ass Message Board' started by Ghost28, Apr 6, 2009.
  1. Ghost28
    Ghost28
    Either early this morning ar late last night some one tossed these in the field close to my house. Not sure what they are from. But thought you guys could help before I toss them in the steel bin. You gotta keep the neighorhood clean. The number on the heads (d3ve-a2a) got a blue paint on them. Have a look.... Thanks in advance...ghost
  2. MichaelDorman
    MichaelDorman
    Those heads are for a Ford 460.
  3. t-town-track-t
    t-town-track-t
    from Tulsa
    FoMoCo heads, big port, probably from a lincoln I think is what the "v" means. They are smog era heads. Probably worth about $50 to the right buyer.
  4. hotroddon
    hotroddon
    1973 and later 460 Ford heads. Not as desirable as the D0VE heads but certainly usable on a big block. Better than the D2VE heads in that they are a closed combustion chamber of about 97cc, while the D2VE were very detonation prone withan open chamber.
    They are NOT Lincoln specific, regular Ford
  5. I'm pretty sure they are for a 1968-72 ford 429/460. 2.09" intake and 1.65" exhaust with 88cc chambers.
  6. hotroddon
    hotroddon
    nope, D3 part number means they first came out in 1973
  7. Mazooma1
    Mazooma1
    D=70's
    3=3
    hense '73
  8. Ghost28
    Ghost28
    Damn... You guys are on it as always. Are they desirable enough to keep them out of the junk pile? And does any hamber have a need for them (free). Sorry local pickup only...ghost
  9. hotroddon
    hotroddon
    Like I said, decent heads, better than the D2VE. I don't need them but someone should.
  10. I thought that seemed off when I typed it. Might have helped if I read the right line on the page.
  11. Retro Jim
    Retro Jim
    I would have left them !
  12. Belchfire8
    Belchfire8
    Maybe s**** steel prices will go back up, I know how heavy those things are; might be worth more as s**** someday!!!
  13. Ghost28
    Ghost28
    Yeah... LOL... At least the field is a litle bit cleaner. And if it snows again, I got weight in the truck now...ghost
  14. 57tony31
    57tony31
    from Woods
  15. PROSTOCKTOM
    PROSTOCKTOM
    I would'nt throw them away, but then I'm a BBF guy.
    Put a ad on Craigslist for $50 and someone that can use them will snap them up in a hurry.
    That way you made $50 for cleaning up the neighborhood.
    Tom
  16. HOT40ROD
    HOT40ROD
    from Easton, Pa
    THe D3AE-A2A heads are 88CC Chambers. 2.09 Intake valves and 1.65 exhaust valve. Not a bad head for street use.
    Same size valves and ports as the early heads, just a larger Combustion Chamber.
