1952-59 Ford One more question on the heater.
Discussion in 'Off Topic Hot Rods & Customs' started by evintho, Feb 10, 2023.
  1. evintho
    evintho
    Where does the capillary tube go that comes off the heater control valve? Mine is somewhat uncoiled and bent up out of the way. There's a clip attached to the end that obviously clamps to something.
    For reference, here's a pic of a NOS heater control valve and cap tube.
  2. evintho
    evintho
    No one? I can't find anything in the shop manual and I'm not entirely sure of it's function and don't remember where it went. I need some guidance!
  3. JeffB2
    JeffB2
    from Phoenix,AZ
  4. evintho
    evintho
    I have that but couldn’t find anything.
  5. Zax
    Zax
    I'll crawl under the dash on mine and look as soon as the weather improves enough for me to take the cover off
    evintho likes this.
  6. jimmy six
    jimmy six
    I thought mine was just inside the black cover and the clip was part of it.
    It’s all out and stored in a box since I added AC/heater combo.
  7. evintho
    evintho
    Appreciate it! LMK.
  8. JeffB2
    JeffB2
    from Phoenix,AZ
    My '54 has the Magicaire Chili-size-platter-2-e1420170164660.jpg heater and does not have that.
  9. evintho
    evintho
    Jeff, I have the exact same MagicAire heater control. Also, the heater control valve is factory and has the capillary tube. I'm at a loss.
  10. Zax
    Zax
    Feed tube through notch marked with blue circle. Clip to indention with red box. If you had the plenum box it would have a corresponding notch at the top.
    I think the idea is the tube reacts to the temperature of the air moving from the heater box to the plenum box. Which would be the airflow the flap regulates.
  11. JeffB2
    JeffB2
    from Phoenix,AZ
  12. evintho
    evintho
    I do and it does! Perfect!
    Thank you, sir!
  13. JeffB2
    JeffB2
    from Phoenix,AZ
    One of the guys in a Ford Facebook Group found this in the glovebox of his '53. Chili-size-platter-2-e1420170164660.jpg
    Zax likes this.
