One piece pan gasket
Discussion in 'The Hokey Ass Message Board' started by CalGasser, Aug 17, 2011.
  1. CalGasser
    CalGasser
    Anyone here have any experience with the one piece oil pan gaskets - before and after comparison? DO they really work? :confused:
  2. badshifter
    badshifter
    Are you talking SBC's? They work IF you have an OEM or quality oil pan and timing cover. If not, 4 piece and sealant. Either works well if properly installed and using parts that fit.
  3. yekoms
    yekoms
    Yep, I'll second that thought...
    Smokey
  4. JOECOOL
    JOECOOL
    They are good but a little pricey!
  5. Blue One
    Blue One
    from Alberta
    On something like a 455 Pontiac engine they are a must have, can tell you that.
  6. hotroddon
    hotroddon
    It's all I use on SBF's now.
  7. willys_truck
    willys_truck
    I have a one piece on 2 sbc and 1 sbf, they work great.
  8. biscaynes
    biscaynes
    yep, the fel pro 1 piece on small and big block work great!
  9. gimpyshotrods
    gimpyshotrods
    Have one in all of my rides. They are good.
  10. Cerberus
    Cerberus
    Love them. Plus they are reusable. I have a one piece on a sbc and a sbf. Installation is easy.
  11. I'll be the first here to pencil in a complaint of a one piece on a SBC. It was installed in my engine while on the stand.
    It ****s because it leaks. I may have installed it incorrectly. So maybe it leaks on me.
  12. Da' Bomb
    Da' Bomb
    I've used them with my 302's and 460 with success. A little more spendy? yup. Beats the hell out of doing the job twice though
  13. rustyford40
    rustyford40
    from Mass Bay
    I used one on my sbf a had no problem with it
  14. Jims35
    Jims35
    Costly ,yes but i use them and like them and have reused them three times on one engine. Proper installation is important ,must be clean and no other sealers used other than what is in the instructions if any.
  15. CalGasser
    CalGasser
    Thanks for the input guys! Even if a bit costly, sure beats the heck out of wiping the undercarriage of oil everytime you go for a drive - that's priceless! :D I'll get on my Summit catalog now... Any pros & cons?
  16. squirrel
    I got the fel pro version locally.
    Feels like I'm cheating when I put them on old 283s from under the car....
  17. CalGasser
    CalGasser
    Why's that, because they fit too good and don't leak? :D
  18. sawbuck
    sawbuck
    from 06492 ct
    cept the color.....i hate that blue.. my pan is polished and my block is black and you cant help but see the gasket....but it does not leak anymore sooooo...
  19. MarkL
    MarkL
    from Tacoma WA
    I bought mine at Orielly's for $20, it came with new pan bolts even and those plastic holder pins
  20. squirrel
    because it's soooo easy to put on!
  21. cheveey57
    cheveey57
    Fel pro all the way
  22. 41woodie
    41woodie
    I hate oil leaks to a point that I pulled the SBC out of the woodie and rebuilt it mainly to get rid of leaks. Used the Felpro gasket with a Champ oil pan. No leaks, period. Happy camper!
  23. barney rubble
    barney rubble
    If you use them the way Fel Pro designed them the plastic pins they come with hold the gasket in place and allow you to push the pan over the pins till they snap through the bolt holes and hold the pan in place.
