Technical One piece windshield in a 49-52 Chevy
Discussion in 'The Hokey Ass Message Board' started by RMONTY, May 11, 2022.
  1. RMONTY
    RMONTY
    So what does it take to put a one piece windshield (Oldsmobile I think) in a 49-52 Chevrolet? Does anything need to be done other than cutting out the bar in the middle? How available are the one piece windshields and the rubber to hold it in place? Suppliers and sources? Thanks for any input!
  2. Gasser_Dave
    Gasser_Dave
    from St. Louis
    I bought my 2 piece windshield from a place up in Minnesota a little north of Minneapolis. He is easy to find on E-Bay if you type in 1950 or whatever windshield.
    RMONTY likes this.
  3. Gasser_Dave
    Gasser_Dave
    from St. Louis
  4. Lone Star Mopar
    Lone Star Mopar
    @RMONTY Try Deep Ellum auto gl***. He provided and cut a windshield for a project a few years back.
    RMONTY likes this.
  5. Marty Strode
    Marty Strode
    There are at least 2, maybe 3 different windshields, Coupe-Sedan, Club Sedan(fastback) and Hardtop-Convertible.
    RMONTY and gimpyshotrods like this.
  6. B Bay Barn
    B Bay Barn
  7. 302GMC
    302GMC
    from Idaho
    54EARL, drdave and A Boner like this.
  8. Boatmark
    Boatmark
    I think Pat Ganahl (Pgan) did an article in Rod & Custom way back when about putting a one-piece windshield in his 51’ Chevy. Had all the details on what fit what and what mods were required on the car.
    If a search doesn’t turn up the article maybe Pat will chime in here with the scoop.
    drdave and RMONTY like this.
  9. Roothawg
    Roothawg
    It's easy peasy. Just trim the center post and install as normal. I did a 50 Fleetline years ago. You can probably do the mods in less than an hour. The installation I farm out.
    RMONTY and drdave like this.
  10. 325w
    325w
    I have installed some of Auto City gl*** in tri 5 cars. Been happy with the fit.
    RMONTY likes this.
  11. drdave
    drdave
    As Root said, easy as pie. Use the Olds windshield for the same body style as your chevy (sedan windshield in yours, correct?). Steele Rubber should have the Olds gasket. Carson Hobson @ Street Rod Gl*** in Riverside CA ( https://streetrodgl***.com) is who I got all the gaskets, channel, etc for my Merc. If I remember right, he's the guy who did Pat's Chevy in the R&C article referenced above. I'd start with him...very knowledgeable and very nice to deal with.
    RMONTY likes this.
  12. dana barlow
    dana barlow
    from Miami Fla.
    In the 1950s n 60s,for custom for two part,into one piece windshields,the trick was to use the Studebaker "V" gl*** that was one of Studebakers ways on saving update $ for there next year,now with a one piece windshield{ mounted in a body design to start with for a 2 piece. Using that Study "V" gl***,let a lot of custom guys have one piece in other then Studebaker bodys. By recutting the Study gl*** a little or redoing the frame hole some.
    RMONTY likes this.
  13. Gasser_Dave
    Gasser_Dave
    from St. Louis
    Don't let the install scare you. clean up the channel real well, use your rust preventative of your choice. let dry and get the gl*** into the gasket. The hardest part of mine was keeping the gl*** in the gasket. squirmy little things they are. Now here is where I went a little differently than most. I used 14 gauge primary wire slathered in dawn dishwashing liquid. Put it inside the gasket. Put the windshield up, lined it up and started from the inside top left. while I pushed in on the windshield, my daughter started pulling the wire out to get the gasket slit to grab onto the frame. we moved about a foot at a time making sure the windshield was in right or whenever I needed a beer. At times a used a rubber mallet to persuade the windshield into the channel. All in all a little over one hour. I suppose I could have gone faster, but its a marathon, not a sprint.
