Only BAD things are going to happen........
Discussion in 'The Hokey Ass Message Board' started by Littleman, Nov 13, 2007.
  1. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    This is my new ch***is table, its 4' wide and 16' long w/ 1 1/8'' thick ground top...........mock-up begins..and only BAD things will come of it....Littleman
  2. dude,
    the blower looks awesome!!!!
  3. noboD
    noboD
    1 1/8, gee if I remember right that's 45 lbs per square foot. Lil' overkill from Lil' Man. Cool.
  4. Destralo Roach
    Destralo Roach
    Now thats a nice lookin model on that there motorcycle lift!! No realy, that is just what every mechaneck needs in the shopp! I just wish my shop was big enough to fit it in!!!...Roach.
  5. Church
    Church
    from South Bay
    I'm salivating already. Build more stuff.
  6. yekoms
    yekoms
    I guess that you're not goin' west. Are you buildin' hot rods as your real job? Have fun,Smokey
  7. PRIMERDAVE
    PRIMERDAVE
    Well then.....keep bad things happening.....it's your destiny..... Luke...I mean Littleman
  8. Scotch
    Scotch
    its like looking at a brand new ****o movie set...
    ~Scotch~
  9. Malcolm
    Malcolm
    from Nebraska
    Haha.... Can't wait to see what starts dancing on that table!!
    Bad. Very bad!
    Malcolm
  10. Harris
    Harris
    WOW - I can't wait to see the first project that comes off that kick *** table.
  11. S.F.
    S.F.
    thats *****in!
  12. Dave L
    Dave L
    from Idaho
    Dam nice table!
  13. Roothawg
    Roothawg
    I bet that is a heavy mofo.
  14. chad
    chad
    Well, when are ya gonna put it to use? LOL
  15. And you're a Bad dude Dave.
  16. AHotRod
    AHotRod
    Teaser ........
  17. Jim Beam
    Jim Beam
    from St. George
    i thought you moved to california? i cant wait to see what your building next.
  18. PeteFromTexas
    PeteFromTexas
  19. racer756
    racer756
    BAD? Blown Alcohol Dragster....
    I've seen these built on "tables" such as yours.
    Good build.
  20. jonnycola
    jonnycola
  21. Nick32vic
    Nick32vic
    Cool Dave. Is it stationary? How high off of the ground is it?
  22. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    Nick, I found the table at a local industrial shop that sells used stuff from thinning or failing companies and small shops...I cut 14 1/2'' off the legs and lowered it carefully back to the ground, then welded plates to the bottom of the legs and drilled and tapped for load levelers, I think the table is like 15'' off the ground now.............and stationary, but can move it with a bigger than me pinch bar, less than 1/4'' at a time, its heavy........I paid 419.00 for it, I believe less than its s**** weight worth...And I could not have built it on my own, just no way to handle that top plate with its size and weight.....Littleman.........and I am not building a Dragster at least this time....
  23. Roothawg
    Roothawg
    That's a steal at 419 bucks. Jeez....I need to scrounge more.
  24. slddnmatt
    slddnmatt
    the engine is to power moving that table around isn't it??:)
  25. A 31 MO FO
    A 31 MO FO
    from D/FW
    Like the table but LOVE the motor do tell.
  26. 392_hemi
    392_hemi
    Wow, what a deal. I think I paid that much for my 30 x 40 x 3/4 top and some 2" tubing. Let's see, 16 x 4 x 45 = 2880. That comes to about .15 per pound.
  27. Gotgas
    Gotgas
    from DFW USA
    Hell, those valve covers are worth more than that. ;) What is hiding under the bumps?
  28. Evel
    Evel
    will you be sitting in front of that?
  29. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Dude..are you gonna need a step ladder to get on that?
