does anyone have this kit a little more reasonable than speedway??? keeps your '32-'48 Ford rear end intact and run a normal driveshaft.
Someone on here did this as a step by step tech article...for the do it yerselfers....I couldn't find it...but its probably cheaper if you have skills. Tim MBL
i'll tackle anything myself, does some one have a link to the tech thread MBL is talking about.......
Smokey did one, it's in the Tech Archives, prefix: Chassis http://www.jalopyjournal.com/forum/showthread.php?t=187
I bought one from Speedway, had my toolmaker dad copy it (not exactly, he made some revisions) and sent it back.
I have been working on this for a couple of months now. The problem seems to be the 8 spline 1 1/4 shaft on the rear end. I have tried thru drive line shops and farm and industrial equipment supplier's but the 8 spline slip yoke seems to be non-existant.My guess is Speedway is having someone with a CNC machine build them just for them. There are 8 spline yoke's but they do not have a very long seal surface. The seal adapter would need to be as long as the splines or the splines could be cut off.The other problem is the U-joint would have to be assembled under the car as these do not have u-bolts. I will try to bore a flange and insert the original piece that runs over the splines and weld it ,using the original outer tube to hold a seal but I'm not sure if it will work. anybody got another way?
The Hot Rod Works makes them. Same price as Speedway. They make an adapter. Goes form the 8 spline to their yoke. Got one one on my '26 Mod, works great.
it will , and has worked ,i have done it myself using a yoke from a 8" ford rear.... smokey's post is way to do it oh yeah , i think you mean 6 spline
this is cool i was going to buy that kit from speedway but with this info i can do it my self. i have one question. i will be using the stock 1939 flatty and 3spd trany how do you hook up a open drive to the back of a closed drive tranny? any help would be nice.
because i need a 3ft long drive shaft. building a short T-bucket. i would love to use a tork tube but don't think i can get one 3 or 4ft long if i can then that would be cool. let me know if some one or some how i can shorten a inner shaft. i know i can do the tube but the inner i can't seem to think how.
Have one end resplined, just like an axle shaft might be. Or just weld the coupler on the back to the shortened shaft.
I remembered this post from awhile back. http://www.jalopyjournal.com/forum/showthread.php?t=34555&page=1&pp=20 They seemed to do it with out too much trouble, and I bet it was alot cheaper and easier than converting both the trans and rear. Hope this'll help ya out a bit Drew
thanks for the link i am having the same shaft they used were The OD gets smaller right after the splines but some one wrote that they found a shaft that was the same size all the way down i mite try and find one of them that would work out better or i guess i could try and weld the shaft to the coupler.? (i will be running a stock motor and trany not a lot of HP or tork there mite be o.k to weld?) thanks guys for all ya'll help
I think that would be the better way to go. either that or find an open banjo truck to rob both the transmission and rear from.
here's a link to a post briefly showing my open center swap http://www.jalopyjournal.com/forum/showthread.php?t=15244&highlight=modified Paul
so do you think i could get away with welding the two? (i know a bit about welding done it a few times wink wink) just not to sure about the tork that would be put on the weld. oh by the way i will be building & giving the T to my wife for her B-Day Aug 18 so i know it will never be ran hard.
very cool but how hard would it be to find one? i have been to a lot of swaps and have never seen open end axle have herd of them but never seen one. do you have a pix of the trany side or did you go with some thing that uses a u-joint?
how hard is it to find? hmmm.... compared to? you are right they are not easily found, but they are out there. that one was found at a local swap meet, cheap, but should get a new ring and pinion before gobs of torque are applied. I would not weld the drive shaft, someone should be able to tell you what the constant diameter shafts are in, or from. I am using a Studebaker motor and transmission in that one.. at least that was the plan,, it'll be an open transmission regardless. Paul
'42-48 ford or merc p/u truck, open drive/use the tranny,cut or lengthen the shaft and use the rear....you can find one cheep.
thanks guys yall have been very help full (this i why i paid so much cash for some cookies. so far every one i have meet has been way cool) thanks again for ya'll help
