Technical Open Drive Shaft for Model A Trans.
Discussion in 'Traditional Hot Rods' started by Speedster, Oct 18, 2013.
  1. Speedster
    Speedster
    from Tacoma, WA
    I'm powering an early speedster with a hot rod Model A engine & Model A trans. Can anyone tell me how to convert the back of the Model A trans to an open drive shaft?
    Thanks
  2. Although they are technically dedicated to "original" cars this might be a good question for fordbarn.com There is a "kit" out there but I can't put my finger on it.
    Charlie Stephens
  3. BobF
    BobF
    from Poway, CA
    Way back when as teens we converted a 36 trans to open by merely changing the rear bearing to a sealed bearing and had a guy machine a flat plate to fit the back of the******* with a couple ears for mounting. The "A" being a three point mount there is no rear plate cover to copy but I think you could make one.
    There may even be store bought stuff available now.
  4. Wonder if you would be better off getting an adapter to a V8 trans from a place like Bert's or Cling's and running the open driveline parts from a forties era truck trans?
    Charlie Stephens
