Hot Rods Open Driveline Conversion
Discussion in 'The Hokey Ass Message Board' started by Rad Crews, Mar 6, 2021.
  1. Rad Crews
    Rad Crews
    Hot Rod Works has a kit to convert an early Ford torque tube drive line into an open driveshaft that can be used with a later model trans. That way the old banjo rear end can be retained. Anyone done this conversion? Thanks, Rad
    HotRodWorks likes this.
  2. 19Fordy
    19Fordy
  3. Kiwi 4d
    Kiwi 4d
    We have done 3 or 4 HRW open drive conversions. On our first one i could not get a decent pinion seal , constant leaks. Put it together exactly as they said . I decided to make a dummy seal from aluminium to help a positive alignment for the seal housing , fitted the dummy aluminium seal ,tightened the housing bolts, removed the dummy. Then lubed it up and slid the seal in , all work great now . We have also fitted the HRW slide in axle conversion in the same banjos, nice stuff. HRW have a top product.
    warbird1 likes this.
  4. Rad Crews
    Rad Crews
    Thanks guys. I appreciate the feedback.
  5. HarryT
    HarryT
    I just converted a '40 rearend to open drive using the HRW kit. Quality product and easy installation. The 10% discount for Alliance members is nice too.
    Jim
  6. Rad Crews
    Rad Crews
    10%! Nice, I'll be sure to let them know. Thanks
