Technical opinion glass vs acrylic
Discussion in 'Traditional Hot Rods' started by S10_37, Jan 19, 2021.
  1. S10_37
    S10_37
    need gl*** for my 31 model a tudor, excluding windshield. was kicking around using acrylic but worried about scratching and or clouding. shipping to 67301 is almost as much as the gl***. I 'll probably bite the bullet and get gl*** but was interested in other opinions regarding acrylic.
    Sent from my SM-J727R4 using The H.A.M.B. mobile app
    dana barlow likes this.
  2. greybeard360
    greybeard360
    Not legal as a windshield.
    mgtstumpy and gimpyshotrods like this.
  3. squirrel
    I have acrylic on the sides of my Chevy II. I use the car for racing as well as street driving...it's seen a lot of miles in the 6 years it's been on the road. The plastic is still ok, but it's scratched and you can tell it's not gl***. I also park it indoors most of the time, so it's not exposed to sun too much.
    For a Model A, that's not a race car, I'd save up to buy gl***. And you'll need to make sure the channels etc that hold it are in great condition, proper size, etc so it doesn't crack.
  4. TCATTC
    TCATTC
    Always gl***
  5. S10_37
    S10_37
  6. flatheadpete
    flatheadpete
    from Burton, MI
    On a Model A it's all flat gl***. Find a good gl*** shop locally and take them some good cardboard or wood patterns and have them cut.
    Just Gary, trollst, grumpy65 and 3 others like this.
  7. chopolds
    chopolds
    from howell, nj
    Shipping? Any regular gl*** shop can cut them out of laminated. Use a local business!
    abe lugo, Just Gary, trollst and 6 others like this.
  8. S10_37
    S10_37
    I go that route
  9. squirrel
    Uh...yeah....that was a true statement a few decades ago. These days, it's kind of dicey. Not many shops know how to make laminated gl*** that fits and has properly finished edges.
    If you don't have gl***, making the pattern can be challenging, too. Use 1/4" masonite, and make sure it fits and works like it should. And check that the cut gl*** matches the pattern, before you pay for it.
  10. Definitely gl***. I have changed one side of a split windshield and a door window as well. Both flat gl***. I took the damaged pieces to a local window/gl*** shop and had them copy them using laminated gl***. When I got them home I found the edges were quite rougher than I liked and the door gl*** could use some work to better match the original. I took a shot and hand sanded them both. Worked GREAT. I was even able to sand enough off the door gl*** to get it to fit better. Now, when I say 'hand sanded', I mean it. I did not use anything but sand paper and a block of wood ... keeps the heat down (which may or may not be an issue). I don't remember the grit I used by some experimentation will determine what works.
    squirrel and S10_37 like this.
  11. Jokester
    Jokester
    Gl***! Check with Danmark/Whistler. If Mark doesn't have it maybe he can refer you. I got some there years ago when it was just Whistler. Don't know if they still carry flat laminate gl*** or not. You may have to go to Coffeyville or Bartlesville.
    Read and digest posts by Squirrel. He knows all.
    .bjb
    bchctybob and S10_37 like this.
  12. S10_37
    S10_37
    about mile from where I reside.(Whistler Gl***)
    bchctybob likes this.
  13. 1971BB427
    1971BB427
    from Oregon
    Gl*** for mine, and never even considered anything else. It was actually pretty cheap, and so was shipping. Whole 9 piece gl*** set for my '39 Chev coupe was $330, and $30 shipping.
  14. flatheadpete
    flatheadpete
    from Burton, MI
    Good advice. I use luan (SP). It's the underlayment stuff sold for flooring at home inprovement stores. It's cheap, easy to cut and shape and is damn near the perfect thickness. And...it can be repurposed after the gl*** is done!
  15. HOTRODPRIMER
    HOTRODPRIMER
    Gl*** for a street driven car. HRP
  16. Budget36
    Budget36
    The few gl*** shops around here, don’t have the patterns for old stuff anymore. None would measure and cut for my ‘36 PU. Only thing they cut is house panes. Seems it’s more efficient to order gl*** needed for newer cars and just install it.
    There’s a few HAMBrs who do gl***, no experience with them though.
    squirrel likes this.
  17. Moparfun
    Moparfun
    I have to agree, go with gl*** the acrylic will scratch after a while, another option might be Lexan with marguard but you'll be paying the same price if not more than gl***.
  18. S10_37
    S10_37
    Whistler gl*** independence ks will cut just supply patterns yeah
  19. BJR
    BJR
    Gl*** is traditional.:D
  20. spanners
    spanners
    Over here in Australia we have to use Tempered in side gl*** and preferably laminated in front screen unless it's original tempered screen. Engineers won't p*** it for inspection otherwise. You either cut a template yourself or get the windscreen mob to do it. They cut the normal pane gl*** and then send it out for tempering and it must have the armourfloat watermark on it or it's not legal. Sounds expensive but for fresh gl*** that fits and a bit of mucking around I reckon it's worth it. You can get a slight tint done at the same time.
  21. That's what I was thinking. Around here acrylic cost is higher than gl***.
  22. Mr48chev
    One rule for getting flat gl*** cut for old cars. Find the oldest auto gl*** shop in the region that has been in the same building for decades. They either have the patterns or don't spook when you roll your car in to have gl*** put in it.
    Speaking of smoothing out the edges of gl***, this popped up on FB market place last night for a dirt cheap price and I bought it this morning and it came with about 50 belts. I didn't know my camera had a black and white setting.
  23. Illustrious Hector
    Illustrious Hector
    I used tempered in the back window and front door gl*** and tinted lexan in the rear side windows. The clear lexan scratches very easily.
    I had the rear window filmed with 10 % tint, The gl*** guy said any darker tint will cause tempered gl*** to shatter on a hot, sunny day.
    I have seen this happen to cars in impound when I worked in a Tow yard.
  24. I use acrylic for side gl*** and rear if it flat. But I do it to save weight and I have a bunch of it.
    For the most part I agree with @squirrel if you are building a hot rod and gl*** is an option buy gl***. Acrylic is not optimum, if you have it on hand it is easy to work and will save money. But end of the day you are way better off with gl***.
  25. chevy57dude
    chevy57dude
  26. Artworx
    Artworx
    Perhaps a comment about the "bug" or stamp of quality would be worth a mention. You can get a ticket if you don't have a big on each piece here is sunny Cali. I worked near a gl*** shop for a while and they knew someone who could come by and sand-blast the bug in smaller pieces. Huh! Maybe that was just for tempered?
  27. I think that probably it is a good idea to check local laws before making a decision. I do not know of a state that would allow it for a windshield. Unless it falls into a historic situation and it is a boat style windshield on a roadster. For example, I know of a 64 Corvette roadster. A factory off road car that came with a short boat style windshield, no side gl*** and the little bumps behind the seats that taper into the deck lid area.. It is do***ented vehicle and it is street legal. The guy can only run a historic tag which legally limits his driving here in Missouri, but no one checks really and he don't drive it much anyway.
    Here is a thought that none of us are thinking about when it comes to the legality/safety issue. How many of us drive without wipers. This is not to say that i would really want an acrylic windshield and defiantly would not recommend it but it is something to think about. ;)
  28. Lloyd's paint & glass
    Lol yeah everybody is correct, acrylic, lexan, plexigl*** is more expensive than gl***. Lighter? Yes. Safe? Yes. Stored inside it will last a while. But i think most people use it as an alternative because gl*** is intimidating. I wish we were all closer, I'd help out anyway i could.
    Jrs50 and chevy57dude like this.
  29. LOL when the current project gets that far I will probably send you a pair of windshield frames. As much as I like my Lexan I will not use it for a windshield. If my belts let loose I want to p*** right through the hole. :D :D :D
