Technical Opinion on paint removal
Discussion in 'Traditional Hot Rods' started by James Mundstock, Jun 28, 2021.
  1. James Mundstock
    James Mundstock
    I need to strip my 47 Ford to bare metal. Sanding is time consuming and dirty, dustless blasting seems expensive, and dry ice blasting seems the best but I’m having difficulty finding a source to get a price. I live in Cincinnati. What are opinions out there? Thanks.
  2. The easiest way is to open your billfold and pay the dustless blasting people. I've always chemical stripped, because i hate dealing with the residual sand from sandblasting, but these days the paint stripper ****s donkey ***.
  3. Everything I've seen or read about dustless blasting is it's much less messy than conventional sandblasting and more 'controllable' as to where it goes too.
  4. junkman8888
    junkman8888
    If you think sandblasting makes a mess, try soda blasting, it's worse.
  5. wvenfield
    wvenfield
    The old stuff was good stuff.
    guthriesmith likes this.
  6. Hollywood-East
    Hollywood-East
    Rip. Captain Lee's...
    Algoma56 likes this.
  7. Jalopy Joker
    Jalopy Joker
    as miserable of a job it is, stick with sanding - need to minimize the amount of products that get into areas that you will never get it out of - once the painting begins all it takes is one pocket of blasting bead, etc to be disturbed and fly into paint - ask guys that have gone to Bonneville and had their car/truck rust from the inside out how impossible cleaning off salt is - similar to pressure cleaning residual
    Flathead Dave likes this.
  8. Fortunateson
    Fortunateson
    Use those 3M stripping discs. Fairly aggressive and they last a decent amount of time.
    fauj likes this.
  9. lippy
    lippy
    from Ks
    Just have the dustless blasting guy do the jambs and sand the rest off. Lippy
  10. Onemansjunk
    Onemansjunk
    from Modesto,CA
    I agree with Fortunateson. Find a slow RPM grinder / polisher and purchase a 8” 3M Stikit pad with 80 grit paper. Be careful on edges and peaks. Start away from anything you will destroy and in time you will get the hang of it. If you run into Bondo and it’s still performing leave it . Use a smaller device to get close to important things.
    Guy Patterson likes this.
  11. inthweedz
    inthweedz
    I've used a heat gun on a couple of my cars (the Nash in my profile was one of them) to remove all the old paint, just don't get the panel too hot (watch for the paint to blister slightly) then use a good sharp s****er/chisel. Didn't take too long, from memory a couple of days..
    (Hell, with a bit of practice, you can s****e with one hand, and heat with the other at the same time)
    Then finished off with an orbital sander to get rid of the remains of original primer traces, and bring it back to the all metal look..
    A couple of times the panel got a bit hot and bulged, but when it cooled, it went back in to shape, with no sign of damage..
  12. mcmopar
    mcmopar
    from Strum, wi
    Im a dustless blaster, and I just did a 1970 split bumper Camaro body. It took about 5 hours and done. As a painter I understand the sand in spots, but I would rather spend the time cleaning sand rather than sanding. Yes I know that this is not the Camaro. This is a 1938 dodge cab.
  13. chopolds
    chopolds
    from howell, nj
    I've converted to paint stripper discs. Fast, but dusty.
    fauj likes this.
  14. unfinished
    unfinished
    Yes and I only tried soda blasting on one 41 Ford fender and it didn’t remove rust
  15. brake1000
    brake1000
    from ID
    You could contact one of your local tool rental places, for dustless blasters.
  16. razoo lew
    razoo lew
    from Calgary
    Buy a 50 dollar Wen variable speed polisher online, get a hook and loop backer pad and a handful of 80 grit discs. Start on larger flattish areas until you get the hang of it before you work around body lines and profiles. You will remove a lot of paint in a day. Worked for me.
    fauj likes this.
  17. The big question is what does it cost for you to come strip a car? And cleanup wise, I'm not talking about the dustless process, I'm talking about the old school sandblasting. I have 2 in my shop at the moment that have been sandblasted, and it's a mess. Plus whoever did the work destroyed a lot of good sheetmetal.
    rpm56 and fauj like this.
  18. 1971BB427
    1971BB427
    from Oregon
    I've stripped my last three cars using Easy Strip discs on my 4.5" angle grinder. Two discs will easily do it, and barely get into the 2nd disc, unless it's multiple coats of paint. And in around 4-5 hrs. with ease. I love them.
    And they're easy on the metal, so no overheating, or too much metal removed as there is with sanding discs, or flapper discs.
    https://www.empireabrasives.com/4-1...cZJCHo0lcUStfkhJq0DY7p3k6z1_KVUhoCji8QAvD_BwE
    Nailhead Jason and fauj like this.
  19. Nailhead Jason
    Nailhead Jason
    Ive used the strip it disks like above and also used a flat twisted wire wheel on a 4.5 inch grinder with great results as well. Less than 30 bucks and four or five hours ought to have you done.
    fauj likes this.
  20. Fortunateson
    Fortunateson
    Yep, that's the stuff I was referring to.
    fauj likes this.
