COE Opinions please
Discussion in 'Off Topic Hot Rods & Customs' started by Homer41, Dec 12, 2023.
  1. Homer41
    Homer41
    Now that I will be moving the engine to behind the cab I have a huge void under the cab. Thought about moving the gas tank to under the cab. Great idea, good idea, terrible idea, what do you think, let me know. Dave
  2. Flatrod17
    Flatrod17
    You could put it there. But you would be pretty much sitting on it! About like a Model A with it in your lap. But then the 05/06 Ford GT has the tank in the middle under the tunnel, (its rear engine). Might work out well as there is enough truck around you if you were to get in an accident.
  3. Flatrod17
    Flatrod17
    Looks like Getfuzzy has his in his 40 Chevy under the cab! He has posted some good pictures.
  4. Getfuzzy
    Getfuzzy
    from NE Ohio
    Yep it’s under there. For my set up it was the best spot, and one of the safest. I think. E8CD616D-A7F4-414E-A080-3F23ED54CCEB.jpeg IMG_2138.jpeg
    b-bop likes this.
  5. scott selvidge
    scott selvidge
    That is exactly what I did with mine.
    b-bop and Getfuzzy like this.
  6. Here's the way I look at fuel tank location; If you get hit hard enough to rupture the tank, will the impact kill you anyway. We don't have friendly crush zones and air bags! I don't want to be roasted alive, but if dead, it doesn't matter much. (I'm probably going to hell anyway)
    What is around the tank is as important as where it is located. Remember the infamous Pinto! The fuel tank wasn't the problem, but in a rear end crash the tank got shoved forward into a shock bracket on the rear axle that ripped the tank open. Ford fixed the problem by putting a piece of plastic in the crucial spot.
    Mine will be up in the bed just behind the engine, no room under the cab, because of other stuff and a clear air flow path to the radiator which is behind the seating area.
    b-bop likes this.
  7. b-bop
    b-bop
    I have been pondering the same question. I look at all of the big rigs out there with their big round aluminum tanks hanging on the outside of the frame rails and think, if it’s my time and someone t bones me hard enough to crush the frame and the tank under the cab, maybe it’s my time to depart this wacked out planet.
  8. 29tons
    29tons
    If someone departs the planet please let us know if they have coe s at the new place
