Projects original 3100 pick up
Discussion in 'The Hokey Ass Message Board' started by belgiumcustomshop, Jan 4, 2014.
  1. belgiumcustomshop
    belgiumcustomshop
    from belgium
    new shock absorbers
    electric starter
    this jack was in the trunk is it the original one?
  2. belgiumcustomshop
    belgiumcustomshop
    from belgium
  3. AnimalAin
    AnimalAin
    Very cool project. Have fun with it.
  4. FrankyV8
    FrankyV8
    from Holland
    Cool truck, looks hard as nails! Could you make a better close-up pic of the rear drum!
  5. belgiumcustomshop
    belgiumcustomshop
    from belgium
  6. belgiumcustomshop
    belgiumcustomshop
    from belgium
    I have to put a new thermostat, This one has had its day
  7. rusty1
    rusty1
    ...you should bend that shock mount back to 90 degrees, they get bent in use, it should be 90.*
  8. HOTRODPRIMER
    HOTRODPRIMER
    You are correct sir. HRP
  9. ct1932ford
    ct1932ford
    Looks like fun! Good Luck.
  10. 4444Design
    4444Design
    looks like a cool base
    lookin' forward to the progress
  11. belgiumcustomshop
    belgiumcustomshop
    from belgium
    small update:
    the truck p***ed the inspection and and got my papers and insurance. I drove it a few times here around the town and to a lokal car show. people loved it.
    painted rims and new tires;
    at the show:
    volvobrynk and s55mercury66 like this.
  12. belgiumcustomshop
    belgiumcustomshop
    from belgium
    Went for a sunday drive yesterday!
    Question; to put lowering blocks in the back, is aluminium ok ore better to use metal?
    volvobrynk likes this.
  13. s55mercury66
    s55mercury66
    from SW Wyoming
    Steel (metal) would be better. Stronger. Aluminum can also corrode, usually where you can not see it. You will probably hear other opinions, but that is what I think.
  14. Aluminium lowering blocks are completely fine to use. They are what every single lowered ute in Australia runs (with the exception of air suspension).. and they are legal here. We have a lot tighter laws on vehicle modifications than the US does.. so they will be fine.
  15. belgiumcustomshop
    belgiumcustomshop
    from belgium
    just returned from my steel supplier, no aluminum in stock and metal yes so metal it is.
    soaked the nuts of the rear end in gibbs brand so i can instal them tomorrow.
  16. belgiumcustomshop
    belgiumcustomshop
    from belgium
    new question;
    I have some chroom wheels I whant to try, but I have to put some wheel spacers on it but now my original studs are too short.
    So I'm looking for longer wheel studs just for the rear end.
    Here a picture of the wheels (I know, not everyone's cup of tea but for the moment just to try)
    the spacers:
  17. belgiumcustomshop
    belgiumcustomshop
    from belgium
    Because spring is coming I'm back at it again!
    Changed the oil and gasket in the rear axle (good ide because the level was low, the gasket was leaking and the oil has some sludge on the bottom)
    I have also taken the oilpan off and same thing hear, sludge on the bottom. I change the oil last year immediately after I had it running.
    I cleaned it all up and wanted to instal the new oil pan gasket but it is not the correct one.
    the mud in the oil pan:
    the pan cleaned and painted:
    inside cleaned and new gasket (wrong gasket)
    gasket set
    in the new set are also cork gaskets for the front and back of the pan, not rubber gaskets as installed now on the car.
    can someone explain to me what went wrong? incorrectly ordered?
    also someone once told me that this was not the original engine for the truck.
  18. belgiumcustomshop
    belgiumcustomshop
    from belgium
    ok I think I can answer my own question: on the website of cl***icparts I can see that the 1955-63 235CI gasket set is the correct one.
    So either my papers ore the engine is not correct for the car. the paper say 1949.
  19. belgiumcustomshop
    belgiumcustomshop
    from belgium
    my brother in law has done a photo shoot of my car to use to promote his company.
    And to put pictures on his website, If you like beer check it out: www.belgian-beerbox.be/en/
  20. belgiumcustomshop
    belgiumcustomshop
    from belgium
  21. paleot
    paleot
    from louisiana
    If that license plate came with the truck I know the area it came from. Most of the truck and cars around there are rust buckets! old farm trucks hammered to hell and gone. Nice truck enjoy it.
  22. belgiumcustomshop
    belgiumcustomshop
    from belgium
    No the plate is not from the truck but it was the most rusty plate i have so it fits the truck nice!
  23. bajones238
    bajones238
    from SC
    Great job sir. The world looks better when viewed through five windows.
  24. belgiumcustomshop
    belgiumcustomshop
    from belgium
