Technical Original 32 5 window chop .
Discussion in 'Traditional Hot Rods' started by Flop, Dec 17, 2017.
  1. 48stude
    48stude
    I like it! ^^^^^^ Where were you this evening? You get two demerits you know:p I'm going to try to make it over this week. Bill
  2. 32owner
    32owner
    out there every day till 5
  3. pumpman
    pumpman
    Turned out great.
  4. 392
    392
    Flop the metal work is amazing, artistic sort of way. Your talent is kick ***.
    Flop likes this.
  5. Mark T
    Mark T
    I think he posted it earlier in this thread or one of his other threads but its an Eastwood Contour SCT
    Flop likes this.
  6. chiro
    chiro
    Just took a gander at the Contour SCT on Eastwood's website. An impressive tool indeed. So THAT'S how flop gets the beautiful finished look after the metal work is done.
    -Andy
  7. Flop
    Flop
  8. chiro
    chiro
    I'm sure there is more to it than that, but that is a pretty cool tool though. Hmm...I got a birthday coming up. Time to drop some hints to the wife.;)
    -Andy
  9. 32owner
    32owner
    need opinions on frame for this summer body bare metal and frame black or red oxide primer IMG_20180210_165750647.jpg
    48fordnut, mgtstumpy and Runnin shine like this.
  10. Runnin shine
    Runnin shine
    I say black now if it will work with what you intend to paint the body later.
  11. 32owner
    32owner
    not sure of color yet won't know till I get ready to paint it next winter. it will change 100 times before it happens lol
    Flop likes this.
  12. krylon32
    krylon32
    from Nebraska
    Can't go wrong with a black ch***is
    DeLuxe 32, FlyFisher and sidevalve8ba like this.
  13. 32owner
    32owner
    I agree krylon32
  14. Fogger
    Fogger
    Black, you can paint the side rails a different body color if needed. Your 5W would look great painted black.
  15. Bigbangtheory
    Bigbangtheory
    from ohio
    I have to say black also. Think it would look awesome.
  16. A Boner
    A Boner
    I'll help you out a little.....paint the frame black. Before you put the body back on your black frame, paint the firewall and bottom of body black. Drive it like this for the summer. Then when you are ready to paint the body, go buy some more black paint, and paint it!
    brEad and Bigbangtheory like this.
  17. 32owner
    32owner
    the fire wall and undercarriage are still the factory black and dash so I will probably paint the frame black again. not pulling the body this year maybe next year
    Flop likes this.
  18. Lou kriger
    Lou kriger
    True old school? Red oxide, all you could steal from the Steel Mill. Can’t beat the price.
  19. 32owner
    32owner
    very true bulldog my dad worked in the steel mill here and everything he had had red oxide primer on it swore it would never rust lol
    Flop likes this.
  20. Lou kriger
    Lou kriger
    Yeah I remember in the 60’s especially it being called “red lead” which was used in the Mill’s. Not to be confused with red oxide primer. It was heavy and thick. Brushable but I never seen it sprayed. Highly rust resistant, and I’m sure it wasn’t good for your health.
  21. 32owner
    32owner
    yep that is what he called it
  22. Groovy
    Groovy
    Does the door bind once chopped since it is no longer in line with the lower hinge? What is required to make this work FLOP?
  23. Flop
    Flop
  24. 32owner
    32owner
  25. You got your answer . . . then, after you've looked at the body for awhile, do some killer final finish work and paint the whole car black! If you have a straight car, black ALWAYS works.
    With that said . . . every car I own is black (vintage and modern), so I might just be a tad biased! LOL
  26. 32owner
    32owner
    Running a little pumped up flattie isky thumper, bored runs well put wood floors back in and bare metal covers to match body IMG_20180329_165924432.jpg IMG_20180329_165924432.jpg IMG_20180403_122311546.jpg IMG_20180506_162536908.jpg IMG_20180506_162549168.jpg
    akoutlaw, brady1929, slug and 2 others like this.
  27. Did you need to raise the front of the engine to clear the cross-member (front pulley), or did you cut the cross member? Also, did you "shim" the motor mounts to raise the engine a bit - seems to be a bit higher than usual? How about the radiator mounting pads - stock location, or are they raised a bit as well?
    In my mind, don't believe you can get that later pulley to clear without a bit of "magic". How have you found the cooling to be - with the fan down low like that?
  28. 32owner
    32owner
    it has special motor mounts, runs 180 on hot days. pulley is close but does not hit, stock crossmember, stock rad pads
  29. Erwin
    Erwin
    Did you not leave a spot for the bondo? Because if you did, I'm not seeing it. Nice.
  30. edcodesign
    edcodesign
    Nice job, good luck !
