Hot Rods Original banger, what are they worth?
Discussion in 'The Hokey Ass Message Board' started by BAILEIGH INC, Oct 16, 2015.
  1. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    Well...my hot rod is done. I took a stock 28 that had a fresh rebuilt banger and transmission and swapped it out for a 49 flat head.
    Now I have this banger with only 3,500 miles on the rebuild. How much (ballpark) are these worth? It's an incredible running engine but I have no use for it.
  2. Chucky
    Chucky
    I really don't know for sure, but...
    I'd ask $1000, and be happy to get $500.
    I say that because I sold my running banger (unknown mileage, but ran good), working trans, 5 good wheels and tires, and rear axle / drive shaft for $1000 to one purchaser.
    Maybe I got lucky, maybe he did - I don't really care. I wanted it out of my garage.
    patmanta likes this.
  3. 2935ford
    2935ford
    Do you have any details/proof of what and when was done to the motor.
    Any motor I look at....I base it on those conditions. If the owner doesn't know and doesn't want to pull it apart for inspection....I walk away.
    A provable, nicely built A motor can get $1500. or so around here.
  4. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    No do***entation, other than I know they guy that rebuilt the drive train with his son.
  5. wex65
    wex65
    from WV
    Just reporting on what I found when I parted out the parts I didnt need on the coupe...got something of a surprise when selling the fenders and running gear.
    Sold the running engine/trans for $2,200 although I had to put them on a pallet ready for shipping. A club in MD spotted some parts I had listed on eBay and they couldn't get enough of them. They may not be in major demand a**** a larger percentage of rodders but a**** the original clubs they are highly valued. Front fenders? Like $1,400 for the pair from memory.
    In case you think I have been smoking something, check this one out...you have to scroll down. $2.5k JUST for the engine...
    http://www.ebay.com/itm/1930-Model-A-Ford-Engine-Ready-to-Go-/262018880760?vxp=mtr&hash=item3d018ad4f8:g:v9kAAOSwu4BV25CF&nma=true&si=BsFKqI1M%2FqejeUSqXhdLhCfWtyk%3D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
  6. prpmmp
    prpmmp
    Beautiful Car!!! Pete
  7. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
  8. patmanta
    patmanta
    from Woburn, MA
    I'd check your local Craigslist and see what they're going for locally. In my area, I usually see runners going for about $300 on up to about $1500. I've seen them list higher but I don't think they tend to sell for that since there are a lot of them to be had around here.
  9. theHIGHLANDER
    theHIGHLANDER
    Do a compression and leak down test and record the results. Set it up on a stand that you can safely run it on for a prospective buyer. All that in place I'd start at $1,800 and any less would be up to you. How complete it is makes a difference too. Long block, no carb manifolds, dist, less. Ready to run, more. And hook up the muffler so it can be heard right, not hidden by a loud exhaust. Just my .02...
