Projects Original fan flathead '46 V8 in a model a frame!?
Discussion in 'Traditional Hot Rods' started by AV8Nilebo, Oct 9, 2016.
  1. AV8Nilebo
    AV8Nilebo
    from Sweden
    Hi !
    I am going to build an mechanic fan (original) in my av8.
    Some people say that it will be tight cause of the model a frame and radiator but i think i can manage it.
    Is there anyone who has the measures from the bottom of the fan holder to the top of the fan... if you know what i mean [emoji1]
    And also how much the double standard crank pulley will build (measurement). The crossbeam is like almost 8 cm (3") from the single pulley ive got now.
    Thanks!
  2. GearHead614
    GearHead614
    I had the same problem with my 8ba in my 29 phaeton. there wasn't enough room between the engine and rad to use the drop down fan from an 8ba. I ended up using a generator mounted fan and t******* the blades down to clear my top tank on the rad. but if you had the engine low enough you wouldn't have to trim the blades 20160518_173352.jpg
    kidcampbell71 and AV8Nilebo like this.
  3. AV8Nilebo
    AV8Nilebo
    from Sweden
    Okey !
    So do you know how deep the double pulley is?
  4. AV8Nilebo
    AV8Nilebo
    from Sweden
    It turned out like this gearhead614 [​IMG]
    Do you know where i can find a double pulley for generator?
  5. GearHead614
    GearHead614
    so how is the fan gonna work if it doesn't line up with the crank shaft pulley? you can usually find double pulleys on bigger trucks
