Projects Original paint coupe
Discussion in 'Traditional Hot Rods' started by duncan, Jun 30, 2016.
  1. ss34coupe
    ss34coupe
    Nice work Ron, Did you find that Hurst Mystery shifter nut that went missing? Funny how things disappear and waste our time trying to find them.
  2. Gonzo Steve. I think it fell into someones pocket. LOL I'm reviewing the security footage so I can see where I hid it.
    brEad likes this.
  3. dumprat
    dumprat
    from b.c.
    Did you print that Ron?
    I might need to turn a 4K tach into a 6.5K tach with a new face and a reduction box.
  4. ss34coupe
    ss34coupe
    Good work, Ron, swapping the faceplate of the tach to get the one you wanted. The guys are going to go nuts over this build when it is finished! You have set the bar high and are not prepared to flex on anything, will be a real hot rod when done.
  5. Long story short Matt. I bought a junk Tach to get the bezel and gl*** for the speedo, kept the face for futures, which is the present.
    Stogy likes this.
  6. Thanks Steve.
  7. Thor1, Stogy, brEad and 2 others like this.
  8. Thor1, Stogy and Fordor Ron like this.
  9. Thor1, Stogy and brEad like this.
  10. Thor1, brEad and Nailhead A-V8 like this.
  11. Beautiful Iron
    Beautiful Iron
    from Upstate NY
    Is your door stand wearing levis?
    metal work is looking good.
    Stogy likes this.
  12. Thanks Iron and yes, my stand is wearing LEE's and duck tape, they stand up much better than the foam padding
    Stogy likes this.
    Straightening left door hinges. This poor door has been through a war.
  14. So, at some point in its 85 years, this door has flown open and badly hyperextended the frame and hinges. Must have been a long time ago, as it was worth repairing. You can see that the inner panel was cut out and welded back in. What you can’t see is that the hinges were torn from their mounts, the frame was straightened and then welded back together. A Valiant effort by some Metal Mechanic in bygone years. I just reinforced it a bit and straightened the hinges to fit. IMG_4740.JPG IMG_4741.JPG IMG_4742.JPG IMG_4743.JPG
    Thor1, Stogy, kidcampbell71 and 3 others like this.
  15. Thor1, Stogy, brEad and 1 other person like this.
  16. Thor1, Stogy, loudbang and 1 other person like this.
  17. Rehpotsirhcj
    Rehpotsirhcj
    I can't get enough of great metalwork. Good job. [emoji106]
    duncan and loudbang like this.
  18. Elvis100
    Elvis100
    Thor1, Runnin shine, Stogy and 2 others like this.
  19.
    Stogy and loudbang like this.
  20. Thor1, Stogy, brEad and 1 other person like this.
  21. Thor1, Stogy, brEad and 1 other person like this.
  22. Thor1 and loudbang like this.
  23. Working on the rear brakes today, using 48-51 F2-3, Bendix backing plates which have no emergency brakes.
    The Hot Rod Works axle ends were installed and welded by a local machine shop and the backing plates had the center register hole opened up and I elongated the mounting holes using an end mill. Everything is ready to go. I used late 40’s p***enger emergency levers, wedge cut 1/2”-9/16” in length to clear the lower return spring and give a bit more stroke. IMG_4877.JPG IMG_4878.JPG
    I used 70ish Ford F250 equalizer bars and shaved them on the top a bit for more clearance. IMG_4880.JPG
    This allows me to clear the spring and lines up better with the cable entry. IMG_4879.JPG
    Thor1, Runnin shine, Stogy and 3 others like this.
  24. dumprat
    dumprat
    from b.c.
    Are you running Buick drums on the rear?
  25. Thor1 and Stogy like this.
