Projects ORIGINAL Vin # TAG and Title Question
Discussion in 'The Hokey Ass Message Board' started by 19Fordy, Oct 20, 2025.
  1. 19Fordy
    19Fordy
    Is it ok to sell an original Vin.# metal tag and transferable ***le from one vehicle to another vehicle
    of the same year, make and model ? Example: 1956 Ford F100 pick up.
  2. Oneball
    Oneball
  3. jimmy six
    jimmy six
    I believe it’s illegal in every state…..but I’ll also bet they’re at least thousands of early Fords along with 55-57 Chevrolets and 67-69 Camaros with that done!
    Just think of how many 55-57 Chevrolets 4 doors are now 2 doors “without” a vin tag change. You better know what you’re buying today!
  4. woodiewagon46
    woodiewagon46
    from New York
    It's only OK if you are trying to do something illegal. After you get the tag and ***le, are you going to re-stamp all the numbers to match the new tag and ***le numbers?
  5. ekimneirbo
    ekimneirbo
    Well, you wouldn't want to tell the DMV that you did it, but just remember that in the normal course of building these old hot rods, we buy new frames for old cars, and switch bodies from one original frame to another original frame. The frames may have different serial numbers from the factory. It gets to be a real sticky issue if someone tries to explain every possible exception that we do. If you have an original frame and you mount a Brookville body on it.........ARE you committing a crime? Then later the frame is replaced with a new reproduction because the old one cracked.....ARE you now a criminal.
    I think as long as you use the same logic you use when your wife asks......."Does this dress make me look fat?", ..........you should be OK.
  6. I am not going to tell you to do it, but I will also say that the drive train is supposed to match the serial number.
    I am sure that every V8 manual 55-57 Chevy, V8 Mustang and Camaro serial numbers are V8s;)
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    there is a really good reason why ***le card buying and selling is not allowed in the cl***ifieds here... because it is illegal and unethical to do so.... period
