Technical OT AMC help
Discussion in 'The Hokey Ass Message Board' started by Racer29, Jun 17, 2018.
  1. Racer29
    Racer29
    I am helping my pastor try to get his OT AMC vehicle running. I am stumped and don't know where else to turn but the wealth of knowledge of the HAMB. I can give more vehicle details in a pm so as not to clog up the forum with an OT thread. So if you're willing to help please pm me.
    The short of what's happening...He drove the vehicle and it ran fine. Went to drive it again and is getting no battery power to anything...headlights, ignition, dome light, acc., etc... You can jump the solenoid and the starter engages so power is at least there but somehow not going anywhere else.
    I have pulled every fuse, looked for fusible links, loose wires, cables. Just can't figure what's going on.
  2. Deuces
    Deuces
    Bad engine ground wire or battey cable?????
  3. Motor City
    Motor City
    from Michigan
    Without knowing the vintage, look at the ign switch. And start tracing from there.
  4. upspirate
    upspirate
    Fusible link or main fuse ?
  5. squirrel
    get a test light, and start at the battery and work your way out from there.
  6. sevenhills1952
    sevenhills1952
    I know quite a bit about AMC, but I need information. OT AMC?
    Specific info. I can probably help.
    Sent from my SM-S320VL using Tapatalk
  7. LM14
    LM14
    from Iowa
    Lots of AMC products had a big, soft, pink fusable link in the wire loom on the firewall. Open the loom just above the heater and work towards the master cylinder, that's where they usually are.
    SPark
    squirrel and upspirate like this.
  8. Racer29
    Racer29
    Thanks for the needed info. I'm going into this with very little knowledge of the AMC world.
