OT problems with tach
Discussion in 'The Hokey Ass Message Board' started by OlSkooDodge, Apr 20, 2007.
  1. OlSkooDodge
    OlSkooDodge
    from Tucson, Az
    I just put a tach in my F-150 (I know it's not traditional, but you people know alot anywho) and I accidentally hooked it up to the positive side of the coil. then when I hooked it back up to the negative side, it doesn't work. Did I fry it by hooking it up wrong?
  2. OlSkooDodge
    OlSkooDodge
    from Tucson, Az
    Come on, somebody has to know....
  3. tjm73
    tjm73
    Have you called the tach manufacturer and asked them? That's what I would do.
    Do you have a multi-meter? You should be able to check it for continuity.
  4. Bluto
    Bluto
    This stuff actually is bulit with smoke inside. When you screwup you let the smoke out and it quits working :cool:
