Projects OT: Ratrod reckoning
Discussion in 'The Hokey Ass Message Board' started by ELpolacko, May 23, 2012.
  1. jhutch713
    jhutch713
    Wonderful fab skills, I appreciate your thread even though I don't necessarily appreciate rat rods. I agree with some of these guys on here, the guy that built that "thing" to begin with should be taken to court for carelessly endagering the lives of innocent citizens. Later on.
  2. Mike
    Mike
    We can rebuild it...better, faster, stronger... nu-nu-nu-nu-nu-nu...
  3. gassersteve
    gassersteve
    girls are groady
    bct likes this.
  4. LOWBLAZERO1
    LOWBLAZERO1
    wow looking damn good. its gonna go from ratrod, to bad mother****ing hotrod! i like the way it sits, and the body. looks like thats pretty much all that you are keeping!
  5. slickhale
    slickhale
    from Phoenix
    [QUOTE
    Better? Now go put some ice on your swollen clam and have a Fresca.[/QUOTE]
    Still laughing at this.....
    Someone please explain to me why Elpolacko's tech threads cause so much *** puckering? If ya quit whining you might learn a thing or two.....
  6. ELpolacko
    ELpolacko
    It was about this point where Mr Funk reached his ultimate frustration with the Scud-Hud. He wanted Dr Marvelus and I to remove the silly ammo box wiring control system, seats and expanded metal drive shaft tunnel to get the floor out. At the same time to investigate why the rear axle was offset to right by over an inch.
    What we found made us quicken our pace at deconstruction. There was literally everything from a dollars worth of Nickles to exhaust U-bends, Rebar, All Thread and multiple layers of s**** metal that made up the floor. All manner of square tubing and plate was used to weld the rotten body to the frame. Two flex plates copped it for the seat mounts and they were cut in half so haphazardly that who I ***ume was Mr Puerile that had done this work, filled over a 1/2" gap with MIG weld to attache the half flex plated to the 16 gauge sheet metal floor.
    Now we were getting down to the meat of the matter. Just how so much of this car got off track and why so much was out of square. The frame rails were tapered, narrower at the front than the back under the body. However, the builder squared the crossmember tubes to the right side frame rail making the cross beams not square to the centerline of the car. This mistake was further compounded in the rear kick up that supported the entire triangulated four link system. While the brackets were close to correct on the axle, the frame they were attached to were not.
    My judgement was to cut the rear kick up off and the last rear cross beam and try to rebuild the frame from there back. After deconstruction it was clear that there was no saving what was left without many hours of laborious work and for little gain. It all had to go. Out came the Air-Arc to remove my clip from what was left of the sorry frame.
  7. Thanks Steve for letting us have a look at your work. Outstanding as usual.......I just happen to be using a torsion bar suspension on my rear motored Falcon.......great timing thanks!
  8. Public shaming would be too good of a punishment to the "builder"
    Your description on the phone blew me away, the pictures make me laugh uncontrollably
  9. EnragedHawk
    EnragedHawk
    from Waco, TX
    Man, that's some amazing work! (and I mean what's being done now)
  10. ELpolacko
    ELpolacko
    Back to the computer for me. I had to construct a simple and cost effective frame that would actually work well with what I had already created but didn't rupture Mr Funk's wallet. I also needed to reuse as much of what already existed and keep it all under the envelope of the body. I regret my decision (you will see later) but the end result works quite well and Dr Marvelus and I can finally cut this project short and get back to repairing.
    I chose a triangulated rear four link system with a air spring mount that keeps the end caps of the bellows parallel to each other.
    While doing my set up for the upper bars of the four link system I found the last bit of rubbish I had to deal with. While the lower fourbar/coilover brackets were at least centered on the housing, they were not clocked properly. The right side bracket was at least 15º forward of the left side. This pushed the rear axle back over 1/2" on the right. They had to come off.
    dirtracer06 likes this.
  11. need louvers ?
    need louvers ?
    Awww, you guys pulled out the nickles? Really!? That and the flex plates were the best parts!
  12. ELpolacko
    ELpolacko
    The lower bars of the rear four link are a bit complex, but considering what I am going to ask of them they will need to be heavy duty. The sides consist of 10 gauge Cold Rolled steel plate, machined bushings and a length of 1.25" CR Bar threaded with 3/4" 16 on the end to accept the Heavy duty HEIM end.
    Then the rest of the ***embly came together rather quickly. Upper bar and bellows mounts, and damper strut mountings.
    I reversed a Corvette steering gear I had lying about and attached it to a mount sprouting out the back of the left front frame horn and then fabricated a new steering arm to finish up the front. A set of engine mounts and transmission pad to tie up all the loose ends before dis***emblely and final weld out of the frame.
    Off the table and onto the floor for another mock up. This time with the new wheels and tires, no adapters and a whole new at***ude. These last few shots are without the bumpstops in place, so yes, the frame can touch the ground. With the stops in place it cannot.
  13. ELpolacko
    ELpolacko
    There is still quite a bit for us to do yet, but for now it's off the table and is ready for true progress for a total redemption. While it may not be your style of car, it will be a sound and safe driving car with a flair.
    Dr Marvelus and I will be repairing more of the bodywork, installing a true floor that seals out nature. As well as adding a few styling cues that will help prevent the Scud-Hud from being terribly dated and keeping Mr Funk happy for miles to come.
  14. patrick66
    patrick66
    The work you guys are doing is beyond great! It would've been very easy to have simply taken that original abomination and sent it directly to s****. You've done what a BUNCH of us on the HAMB wish we could do. Fantastic! Karma is in your favor.
  15. Beautiful work mate. But How the **** can sombody build something that horeie to start with, they must have a pretty vivid imagination to be using nickles etc, or on some really bad acid!!
    I would stuggle to get into their head space.
  16. zman
    zman
    from Garner, NC
    Wow, you can polish a turd...
    Beanscoot likes this.
  17. yetiskustoms
    yetiskustoms
    Yes!:d
  18. Muttley
    Muttley
    Well, there goes the OlSkoooooooooolRodzzzzzzzzzzzzzz cover and tech features. Any idea how much the owner paid to get the original version built?
  19. rld14
    rld14
    $50? $60?
  20. CB_Chief
    CB_Chief
    from Oklahoma
    I on the other hand am clicking on the "subscribe" option, I like seeing a master craftsman at work.
    Larry
    CB_Chief
  21. llonning
    llonning
    Steve, as usual your work is outstanding!! As for the nay sayers, they just don't understand what you are doing here. You, Sir, are trying to teach!! At least there are some of that understand that.
    Teach away, I am ready to learn!!
  22. Jim Dieter
    Jim Dieter
    from Joliet
    That rear link/bag alignment rod is a cool set up. Very nice.
    I think you mentioned it in another thread, but is your graphics program one of the autodesk types ? Like inventor ?
  23. Joe Jackman
    Joe Jackman
    from SoCal
    he's using Alibre. not sure which version.
    http://www.alibre.com/
  24. did the prior builder just happen to have an abundance of connecting rods???? All I can say is thats one hell of a recovery, you guys are doing a great job!
  25. Joe Jackman
    Joe Jackman
    from SoCal
    incoming ***** questions:
    i see both mig and tig welders. what is the factor in deciding which style of weld to use?
  26. Stevie Nash
    Stevie Nash
    Well, ignorance is bliss right?! If you're not smart enough to know that you don't know, then hell ya, he's quite the artiste!
  27. sodbuster
    sodbuster
    from Kansas
    Is that bad that I scrolled thru all the 'drama' after page 2 looking for updated posts? Great rebuild on this car.........The thing that ****s is that the OG builder is going to tell EVERYONE at car events that he "built" that car & people will see your PERFECT work and say "Wow! Great ideas".
    Chris Nelson
    Kansas
    Oh yea, "subscribed".
  28. BenDaPirate
    BenDaPirate
    WOW. Thank you for getting that **** heap pile off the road and turning it into a very bad *** rod. Looking forward to updates.
  29. 49ratfink
    49ratfink
    got any more pics of the original rear suspension? trying to figure out what is going on there is giving me a headache.
  30. Joe Jackman
    Joe Jackman
    from SoCal
    "The box mounted on studs just aft of the radiator were not sleeved"
    This means the box mounts would wear out in short order and dangerous play would occur?
