OT: sort of, but, Kroil Rules!
Discussion in 'The Hokey Ass Message Board' started by 1952henry, May 12, 2007.
  1. 1952henry
    1952henry
    I used it to soak the stuck throttle and choke shafts on some auction Holley 59s. After a couple weeks, I shot them again and administered a couple of persuasionary smacks with a small hammer, and moved they did!
  2. Bugman
    Bugman
    Yup, Kroil rocks. Save bee's wax, it's the best penitrating lube I've ever used. I've broken loose many a stuck fitting and nut with Kroil.
  3. Jalopy Jim
    Jalopy Jim
    Using it right now on my 38Ford pickup. Getting the windsheils movable and the p***enger door to open. Some bozo cut the hinges on the drivers door.
    By next winter when I start that project it should be all ready to go.
  4. Belchfire8
    Belchfire8
    Great stuff, if you have a hard time finding it to buy try a gunshow, I have found it there for years; I don't know why the stuff isn't available in every store that has a hardware dept!
  5. Deuce Roadster
    Deuce Roadster
    Great stuff ... you can order it direct ... the phone number is on the can shown ... :)
  6. Dirty2
    Dirty2
    I have to get me some of that stuff.
  7. 1952henry
    1952henry
    Order the gallon size-$40+/- shipped, and put it in a two-bit Wally World spritzer. Goes right where you want it to with no waste. Check around your parts houses, supposedly some do stock it. I had checked at the NAPA here; the counter boy comes over and asks what I'm looking for. I say Kroil; he picks up some Seafoam gas stabilizer and says "This?" I only hope his meds kick in some day...:rolleyes:
  8. LordMaximo
    LordMaximo
    from Roy, UT
    We use that stuff at work all day long. Saves time.
  9. 6inarow
    6inarow
    How is the stuff compared to PB Blaster penetrant?
  10. slammed
    slammed
    It rule's...........The oil that CREEP'S!
  11. chilimac
    chilimac
    Without a doubt the best,even loosens turbocharger bolts on aircraft.
  12. banzaitoyota
    banzaitoyota
    Gibbs, Kroil they BOTH rock! :)
  13. rob lee
    rob lee
    from omaha,ne
    best **** i've used,threw everything else away. I found it at percision bearing,but any industrial tool supply should have it.
  14. wvenfield
    wvenfield
    I work at a large well known manufacturing/chemical plant. When I first started there was when I first used "crow oil".
    We use it to hose down all sorts of stuff. You can lay it on alot and thick when you aren't paying for it. Everything is constantly exposed to water and as soon as something starts to stick it's hose it down time.
    Long time before you have to do it again.
  15. 6inarow
    6inarow
    Hope yu guys are right - I bought some and the first test is stuck carbs like 1952henry.
  16. Thanks. I'm going to get some for my stuck heat and blower fan cables.
  17. 6inarow
    6inarow
    unstuck already. thanks for the tip. I bought the gallon and use the wally world spritzer as suggested - works for me.
  18. Blackie
    Blackie
    Any stores sell this stuff, or do you have to order? I'm too impatient to wait on the mail!
  19. axeman39
    axeman39
    from Saco Maine
    If you can find it try some, [Free All] this stuff works awesome and smells good too.
  20. power58
    power58
    Everybody buys it from the factory. Kroil does not have middle men selling their great product. I have bought from them direct for years. You can buy one can or a case. Single can is $11 plus shipping. They used to send COD. Be carefull if you buy from some one else than the factory,they will mark it up on you. A guy I work with said he ordered a case from a new distributor in town. They said it was $230 for a case. I said man that sounds high. I called the factory and they said $95 for a case plus shipping. I understand some mark up, but 50% is goverment type markup. He cancelled the order from the distributor and ordered direct from Kroil for $95 a case.
    Really great stuff you will never used anything else.
  21. 38Chevy454
    38Chevy454
  22. vdubjim
    vdubjim
    from OKC
    it rocks!
    and smells good too :)
  23. kustomizingkid
    kustomizingkid
  24. Speedwagen
    Speedwagen
    This stuff is great for "stuck" engines !
