OT: Welding carts
Discussion in 'The Hokey Ass Message Board' started by rab71, Jan 7, 2008.
  1. rab71
    rab71
    Well, I was going to go to Harbour Freight and buy me a cheap ol' welding cart but then I started looking around the garage and realized, I had more than enough **** laying around.
    Who else builds their own stuff like this? I would think a bunch of doit yourselfers like yourselves there'd be ton's.:D
    Actually I just wanted to show off my new welder...;)
  2. Mr.Musico
    Mr.Musico
    from SoCal
    This was covered a dozen times or so already, some creative ideas out there.
    we used some medical equipment cart we found in the trash behind our shop and a hand truck.
    <!-- / message --><!-- attachments -->
  3. Deluxe
    Deluxe
    Nice work, Man. You just saved yourself around eighty bucks that you can now spend on car parts!!
    Deluxe
  4. chaddilac
    chaddilac
    My cart was my first project after purchasing my millermatic 175.... we only bought the wheels, everything else was s****...
  5. tooslow54
    tooslow54
    looks like there might be a grocery cart missing in your area:D
  6. momentumfoto
    momentumfoto
    from Yes
    I just gave haircut to a shopping cart that someone abandoned behind my shop the other day. Works killer!
  7. Shifty Shifterton
    Shifty Shifterton
    If you shop a little it's not hard to find somebody with a low welder price and free cart thrown in. The lincoln cart is a POS though and the very first thing the welder should be used for.
  8. rab71
    rab71
    I feel that creative ideas should be revisted every once in a while. Keeps the mind going ya' know. Just nice to see what others might be working on besides their car project.;)
  9. NJVadala
    NJVadala
    There's a Tech post that I posted a picture of mine in...I gotta find that. It had three levels, 2 machines (a MIG and TIG), two bottles, and an accessories shelf.
  10. kopis
    kopis
    Yep, I built my own as well. Sure it takes a little longer to make the thing, but once its done it will last alot longer!
  11. ...bed frames work killer for welding carts...you can pick em up used at any Goodwill or Salvation Army. just cut up that angle iron and weld up:D
    -marty
  12. CURIOUS RASH
    CURIOUS RASH
    Classified's Moderator
    Not to hi-jack (nice cart by the way) but how about some home grown torch carts?
  13. rustyford40
    rustyford40
    from Mass Bay
    First welding prog. find something with wheels an make a cart.
  14. Black Primer
    Black Primer
    One thing I learned when I built my torch cart, is to think ahead when making the handles. Just because they look "right" when the cart is standing up-right, dosen't mean they will be comfortable when you tilt it back to roll it around!
  15. RustBucket49
    RustBucket49
    from Texas
    I built a s**** metal cart as well. Used an old stabilizer bar off a '49 Chevy cut in half for the handles and half of a coil spring on each side for the front supports. Used a gate hinge w/ strap metal for the shielding gas cylinder support. Works great and looks like **** - just the way I like it..... Problem is I used all my gas making the cart and now I can't do any real welding.....
  16. mcload
    mcload
    I can't weld worth a **** with my little 110volt wire feed unit; totally dissatisfied with it.
    Patrick
  17. RustBucket49
    RustBucket49
    from Texas
    Flux core or shielding gas? The gas makes a big difference. I can actually half-*** weld old sheet metal w/ the gas. Maybe it's just that we live in Houston.
  18. lowpunk
    lowpunk
    from berwyn, il
    when i bought my last welder the sales guy was sorta pushing the cart. i looked at him with my best confused look and said "isn't that supposed to be the first project of any new welder?" he laughed and knew i got it and ended his pitch.
  19. Bluto
    Bluto
    Mine was left next the the train station by Germans as they ran from the Ruskies.......
    It just sat in the s****yard that grew up around it. I found a piece of ''landing mat'' there too.......
  20. I found some old bed frame rails (angle) in the rafters of my garage, and welded up a bottle cart. Also cut up an old bicycle rack with the rubber coated hooks to wind up the hoses.
  21. hrm2k
    hrm2k
    My garage is in a really really bad neighborhood. The day we bought our welder, we caught a homeless guy going through the dumpster that our landlord allows us to use. We took his cart, made some changes...presto...called in our garage, " Homeless Racing " :cool:
  22. jcruz
    jcruz
    from Austin, Tx
    more! more! anyone else?
    ...need to test a new welder out with a home-built kart, too.
  23. kelzweld
    kelzweld
    I've made a few over the years in different workshops I've worked in. Normally the four wheeled cart type for plasma cutters and smaller migs that aren't self supporting. This pik here is of my cart for an inverter tig. This style is pretty common in NZ for dragging your tig around for site work. Easy to go up and down stairs, a comfortable walking height and it keeps your welder up out of any water.
  24. Just Gary
    Just Gary
